B16A2 question
Old 01-09-2015, 10:58 AM
skyliner34life's Avatar
Icon2 B16A2 question
Hey guys i have a 2000 civic si i was curious if the tempurature switch will throw a check engine light code? There is 3 sensors in total, 1 being for the fan to work and the other is coolant temperature that has 3 wires running to it. I know those have codes but I was curious if the tempurature swtich below the distributor that has one wire going to the gauge cluster will throw a code if bad. Thanks!
Old 01-09-2015, 11:01 AM
Loves Tossing Salad
09chaplak's Avatar
Default Re: B16A2 question
No, the gauge in the cluster just won't work. But I've been wrong before......
Old 01-09-2015, 11:18 AM
Former User's Avatar
What CEL code(s) is thrown?
Old 01-09-2015, 12:18 PM
The only codes thrown are o2 sensors... But i was asking because my car will go to 3 quarters on the hot and cold gauge and go back down... I dont think the car is really heating up... Took it to 2 shops and no luck
Old 01-09-2015, 02:39 PM
92ehatch's Avatar
sounds like crappy shops.
The temperature sending thermistor is typically a single wire sensor. I'm not sure where it is on a b16 but it is under the dizzy on d series.
You can test it with a volt ohm meter.
However i think you may havea fan issue or thermostat issue.
Old 01-09-2015, 02:44 PM
Originally Posted by 92ehatch
...thermostat issue.
Or air in the cooling system. Might just need a proper cooling system bleed.
Old 01-09-2015, 08:08 PM
Ill check into it guys thanks for the replys.
Old 01-10-2015, 03:30 AM
92ehatch's Avatar
While you are checking...fix the o2 codes
Old 01-10-2015, 12:09 PM
I never narc'd on nobody!
NotARaCist's Avatar
Could also be a sticky thermostat. When was it last replaced?
Millionmiles
Honda CR-V & Element
03-05-2015 11:53 AM
MapleK
02-06-2011 08:18 PM
ctr32
08-01-2009 01:56 PM
tuphatt
01-29-2005 08:06 AM
KeithsDAteg
01-04-2005 03:07 PM
Quick Reply: B16A2 question
