What Should I Use On This Steering Wheel?
Old 01-27-2015, 07:32 PM
Omega Blaze's Avatar
Icon2 What Should I Use On This Steering Wheel?
I recently found an Acura Vigor steering wheel for the low : )
Unfortunately, even after lots of cleaning; the SRS portion of the steering wheel is highly faded. What should I use to restore the color of this steering wheel?
I'm thinking about VHT Vinyl Paint. However, I'm not sure if it would work on the SRS portion of the steering wheel since it's not leather (I don't think).
Any help?
Old 01-27-2015, 09:13 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: What Should I Use On This Steering Wheel?
Paint? Why would you paint it? Just get yourself some non-greasy, non-aerosol pleather threatment, and start rubbing.
Old 01-27-2015, 10:23 PM
Would that work on the Airbag portion of the steering wheel? And could you post a picture of stuff I should be looking for?
Old 01-28-2015, 07:38 AM
Retired Moderator
EsotericImage's Avatar
hmm.. maybe tape off the leather and use a scotchbrite pad on the old faded vinyl to make everything one color. If you want it like new, id suggest looking for a replacement.
Paint only gives marginal results and usually looks... well, painted.
Old 01-28-2015, 11:27 AM
NotARaCist's Avatar
Ever wandered through the cleaning section of a parts store? This isn't some super secret stuff I'm talking about. Meguiars, 3M, Mother, they all make something that'll work for you.
Old 01-28-2015, 03:01 PM
ZHundred3X's Avatar
First off, what have you used to clean it?
Old 01-28-2015, 09:05 PM
Hysterically Calm
TomCat39's Avatar
You could also use a dye. That's basically all stain is but the solvents in stain might be a bit harsh on the pleather.
Buying black dye and making your own water based solution with it should let you dye it back to black without issue.
Would be better than paint but probably not color match as it would be a fresh strong black unlike the outside rim that is old and mildly faded.
Old 01-29-2015, 02:37 PM
Oh look, I can change this
deschlong's Avatar
Do NOT paint it, you will be in for disappointment. If I recall correctly, there is a Honda-branded airbag that will fit your Vigor wheel, that right there might be an option for you. From an Accord or Prelude.
deevin9
10
03-23-2007 06:38 PM
JCL
03-08-2006 08:34 PM
rice_classic
01-20-2003 10:08 PM
Quick Reply: What Should I Use On This Steering Wheel?
