Turn Signal Relay Fuse (solved)
I have a stock 93 Honda Del Sol si 1.6. The turning signals don't work at all and the signal relay fuse doesn't click at all. I wanted to test it first before trying to replace the switch which is very costly for me right now. I prefer diagnosing first instead of just replacing parts.
Which relay fuses can I use temporarily in place of the turn signal relay fuse to test it? I don't want to use one that would mess any other function up.
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
re: Turn Signal Relay Fuse (solved)
check your fuses, It's doubtful that both sides of the turn signal switch in the combination switch failed at the same time, could also be the flasher unit blew a fuse, order one swap it in, if it's not the issue, you have a spare, which you should have anyway, along with a few spare bulbs
Paul 631
12-25-2011 07:19 AM
