B20B swap...
B20B swap...
Hello fellow HT members,
So I will be swapping a JDM B20B engine into a 00 Honda Civic SI. Now before I start on this project I want to make sure that I have 1. All the parts I need and 2. Make sure the information I think I know is correct. If you can give me any information or point me in the right direction I greatly appreciate it.
So a few questions, since I'm going B series to B series the factory B16A2 engine harness, motor mounts, and axles can be used correct? This project should be fairly easy since the car already came with a B series from the factory? For the ECU I would like to source a 00 CRV 5 speed ECU but a integra LS ECU is also ok to use? Will I need any ECU jumper for the ECU?
