Gsr swap in to eg hatch
NEED HELP : recently swapped a 98 gsr from one eg hatch to another eg hatch, it used to start right up like beautifully, now in the new hatch, its a process to get it started. It cranks and cranks and cranks won't turn over unless I cover the Throttle body with something so blocking off air flow a bit then it will turn over and start really weak then immediately I have to rev it, after that it starts up fin for a bit, why doesn't it start right up In the new hatch? Anything will help my phone number is somebody knows the issue and will hide me through it 4013099687 thank you!
Fish Twig
Re: Gsr swap in to eg hatch
It was a ls before, I thought it would be a wiring issue cause it was swapped to the same chassis, bit when it had the ls it had a ruff start where I would have to hold the gas so it would gradually start, so I'm trying thinking it's something with the cabin harness
Fish Twig
By the sounds of it, you're not getting fuel properly delivered, or the spark weak. If you have to cover the throttlebody just got it to crank weird than I have no idea what that proves. Probably starvation of oxygen?
That's what I thought with fuel because the motor in it before has a issue like that similar just different, I would start and it cranks over and I would have to press the gas for it to start up fully
T-RO
09-10-2005 07:05 AM
