What engine?
What engine?
Picked up a 97 dx today for $1k and have a few questions. It's had an engine/trans swap done and I have No idea what I'm looking at here so Any help would be appreciated. It's main focus will be a DD with a little oomph. I took a picture of the engine tag. I'm not afraid to get my hands dirty.
re: What engine?
The block is from a Civic HX. Post the head code:
https://honda-tech.com/honda-civic-d.../#post48684945
...and also a shot of the engine bay.
Re: What engine?
Is it Any kind of big deal for smog or getting parts? I still need to run through everything but don't want to get stuck with my thumb up my butt. PO Did a number of WTF things to it so I have to untangle the mess.
Re: What engine?
Looks to me like you may have bought a lemon sir, Mix and match parts are never a good thing even if it was a LS/vtec, or b20 vtec the problem with having this is that , you don't know the quality of the work they did to put it together, also nobody puts together a d series like this because a d series is the weakest engine honda make, granted with couple grand you could boost it but this car will not be reliable, The best thing you could do at this point is to take it to a good shop you trust and have it thoroughly looked at, or perform an engine and Tranny swap, i almost guarantee that if the Block and head are mix and matched it may have a different tranny on as well, People do this to make a quick buck man a civic shell costs 500 Cheap d series parts are something you can get for a couple hundred, he probably already had a few pieces laying around and through it together to get rid of it. TO answer your last question no this is not a vtec-e equipped engine, its not a vtec engine at all, the sohc vtec engines are the Y8 which is what i have but they are just as bad because its a D series also you should buy Dx parts because you have Dx at least if your thinking about cosmetics or anything other than the engine you'll want DX parts aside from the engine your best hope for the engine is getting a new head gasket and a y5 head and have a shop put it together, that way at least both halves will match, Since your engine looks this way i would be sure to take a look at everything else mechanical you're definitely in a scary mess.
Re: What engine?
Re: What engine?
Swapping in a good block on a D series is a cheap fix over a full rebuild as the parts are cheap. The block was a good match up for the Y7 head.
OP you can check out block side parts for the HX and top side parts for the 6th gen DX. You may also want to compare part numbers for the block end between the 6th gen HX and the 6th gen DX and see what all matches up.
The hardest part maybe the timing belt. Water pump will be the HX if the parts don't match between the two models.
I am aiming to do up a D series. I want to get myself a D16Z6 block and a JDM 3 stage (dual vtec) D15B head.
Using just the D15B 3 stage motor and a turbo, another person managed to put down a nice 238 HP with good fuel economy and nice low end torque.
With a built Z6 block I'm sure I can surpass the 238 mark safely and maintain high fuel economy and good low end torque all with a SOHC motor, and all reliably.
Not all D series suck.
And before you go there, I really don't need or want more than 250 HP in my tiny lightweight 5th gen civic for a daily driver.
Re: What engine?
I don't totally agree with you here.
Re: What engine?
OP will be fine with that franken motor.
By the looks it's only a franken motor by stamp.
Compression ratio is the same with 9.4:1 on both motors.
Then looking up the parts for OP. The timing belt is the same on both motors, the rods are the same on both motors, the crank set is the same on both motors.
The only think different on the block part wise is the piston itself. The HX has a piston design more conducive to the lean burn. I'm not sure what that will do to the non lean burn mode head setup. Might tweak emissions a touch but I'm confident it will still pass efficiently.
Re: What engine?
Re: What engine?
DX/D16Y7 engine
...unless you need block replacement parts, in which case buy for the HX/D16Y5 engine.
I'm a little concerned about the aftermarket intake system set up. I don't see the IAT sensor, and the intake could suck in some water during a rain, especially if the splash guard is removed, or could suck in some coolant if the reservoir overflowed. You may want to pick up a stock D16Y7 intake system from a salvage yard.
The D16Y5 block originally came with a VTEC-E head, but this was replaced with a non-VTEC D16Y7 head.
Would this be a vtec-e equipped engine?
Seagull Management
Re: What engine?
It's going to vary with a swapped head since the combustion chamber volume and pistons are different. With that setup you're looking at 9.24:1
Play with this and you'll see:
Honda D-Series Compression Calculator by ZealAutowerks
It will still run fine in this case, but sometimes you'll end up with a ridiculously high or low compression ratio depending on what combination of parts you use.
Re: What engine?
IAT is directly in front of TB on the backside of the tube. Hard to see from the pictures but it's there. I have plenty left to go through. As far as sucking up water, That's always my concern with a CAI. It's gonna take some work but I'm up to it. The front end rattles when hitting bumpy roads and it tracks which ever way it wants sometimes when braking. I'm sure I'll have plenty of questions as I'm new to IFS and import.
Re: What engine?
DX/D16Y7 engine
GDD Member
Re: What engine?
Wow, I can't believe they got that to fit and it looks like it came that way from the factory. I believe this engine to be the 4A-GZE engine that came stock in the 88-94 Subaru Evolution GSR.
That car is worth some serious coin, I would hold onto it forever.
Re: What engine?
This does not help in the least. Trying to be funny is Okay but at this point I'm going for a mini-me as it's pretty simple and I've got half the parts on the engine already. Z6 head, ecu and ex trans.
Re: What engine?
I'm guessing all the vtec-e stuff was too complicated for the shade tree mechanic who put this thing together. I'm happy to do this as I will know exactly what was done. Any idea how to see what trans I have? I'd like an EX because of the shorter gears.
