JDM fog lights installation - In need of some advice.
Old 01-01-2015, 10:26 AM
EG95PR's Avatar
Icon4 JDM fog lights installation - In need of some advice.
First Happy New Years. I need some advice in relation of my JDM fog lights. I want to connect my fog lights directly to my lower beam lights instead of putting an on/off switch somewhere in my dash. Any pointers on that. Thanks.
Old 01-01-2015, 11:09 AM
The Grumpiest
grumblemarc's Avatar
Default re: JDM fog lights installation - In need of some advice.
Uyeah. It's called splicing.
Old 01-01-2015, 11:16 AM
EG95PR's Avatar
It is something that you will recommend Grumblemarc, or you rather to put a switch in the dash.
Old 01-01-2015, 01:39 PM
The Grumpiest
Default Re: JDM fog lights installation - In need of some advice.
I don't recommend hacking wires.
Old 01-01-2015, 03:41 PM
92ehatch's Avatar
What frigging car do you have? On the 92-95 model you simply change the fuse box wire from one location to another
Unless I'm misunderstanding the question.
I think i am.
Take the wires that go to the switch...splice the wires together. If it has a lit up switch find the correct wires
Old 01-01-2015, 04:13 PM
EG95PR's Avatar
Ok, thanks man!!!
Old 01-02-2015, 06:55 AM
Oh look, I can change this
deschlong's Avatar
Default Re: In need of some advice.
SWITCH IN DASH.
"Fog lamps should be turned OFF almost all the time. [...] Fog lamps are meant to be used in heavy fog, rain, or snow to help the driver see the edges of the road close to the car so s/he can safely make progress through foul weather at very low speeds." -danielsternlighting.com
Lay off the bling. It's distracting and glaring for other drivers, and actually makes you LESS safe on the road when used improperly.
Old 01-02-2015, 07:25 AM
crazyhouse2011's Avatar
Originally Posted by deschlong
SWITCH IN DASH.
this, plus a couple bonuses. i just wired fogs into my ranger, and here are the results:
1. You can control whether they are on or not, regardless of the headlights. That's nice.
2. If you so desire, in rare instances, you can run fogs alongside high beams for extra roadway illumination. Do NOT do this with other cars around.
Old 01-02-2015, 08:00 AM
rockycat's Avatar
DOT says to use fog lamps only when low beam is on.
Old 01-02-2015, 08:33 AM
Former User's Avatar
http://autoparts-standard.org/index/...0J583-2011.pdf
7.5 Front Fog Lamp Switching
Parking, tail, side marker, and license plate lamps shall be activated whenever the front fog lamps are activated. It is permissible to switch the front fog lamps on and off independently of the low beam headlamps.
Old 01-02-2015, 08:43 AM
92ehatch's Avatar
Nc law (where i live) does not permit both high and fogs. However i have always done them independent. Keep a switch in dash and leave it set to on.
I grew up in the back woods and having that extra light was and is wonderful. Also nice to be able to park late and not shine lights in someones windows while they are sleeping
Old 01-02-2015, 08:51 AM
sidewayz2013's Avatar
I'd recommend using the switch, as I'm literally about to install mine today. But if you're dead set on wiring them to the Headlights, use a relay, because IIRC if you wire them straight to the headlights, that takes amperage (and therefore brightness) away from the headlights, pretty much negating the fact that you put in fogs for more higher visibility.
Unless you're only putting them in for the look, which... well, to each his own, I guess.
Old 01-02-2015, 01:07 PM
THIS!!!! parking at night without beaming through someones window. and yes, high beams and fogs are illegal. thats why i said only do it when nobody is around
Old 01-02-2015, 01:23 PM
deschlong's Avatar
Interesting. This means the US regs mean fogs can be used independently of low beams. This is not how the OEM wiring works for Canada/USA, however. Power to fogs is only active when the low beams are on. Switching to high turns them off, switching to parking lights turns them off too. This is very very common. High beams + fogs is useless since you shouldn't be using high beams in a low vis situation anyway.
Parking lights only + fogs is actually useful in REALLY inclement weather (like, the kind of stuff you shouldn't be driving in anyway, but maybe you have to for some reason like your wife's giving birth in the back seat). BC regs mirror this, Ontario's do not. Canada is a patchwork of rules vis-à-vis fog lights, though universally the way the Can/US OEM wiring functions is permissible in all North American jurisdictions.
AnalyzeThis29
Lighting
09-26-2015 02:11 PM
cmwalker
01-17-2014 12:06 PM
italianchooch88
02-13-2008 01:45 PM
Basically
03-06-2005 08:58 PM
AMChev
10-14-2003 05:16 AM
Quick Reply: JDM fog lights installation - In need of some advice.
