throttle body hose
Old 01-15-2015, 12:52 PM
The Neutron's Avatar
Default throttle body hose
Hi. I have a 2000 Honda civic ex with a b16a2 swap. I had to go to the reff today (stupid California smog laws) and he pointed out one hose that was plugged coming from my throttle body. He gave me a diagram of where its supposed to go and there is no spot thats missing a hose. Could i just tie it in to any coolant hose?
Old 01-15-2015, 03:48 PM
Former User's Avatar
Default Re: throttle body hose
Post several well-focused pictures of the hoses and nipples in those specific locations of your engine.
Old 01-15-2015, 04:39 PM
92ehatch's Avatar
The one you circled appears to be the fitv.
Do you have an fitv on the bottom of your throttle body?
Old 01-15-2015, 04:54 PM
The stock B16A2 doesn't have a FITV.
Old 01-15-2015, 04:55 PM
92ehatch's Avatar
Originally Posted by RonJ@HT
The stock B16A2 doesn't have an FITV.
Is that just a throttle body warming hose in the diagram?
Old 01-15-2015, 05:03 PM
I believe so.
Old 01-15-2015, 07:51 PM
theres the bolt plugging the hose off the throttle body. not sure if it matter but it says GR ontop of the throttle body
it seems to me there should be a nipple where the arrow is pointing
Old 01-15-2015, 08:04 PM
I'm having problems orienting my view in your pictures. The B16a2 throttle body in the exploded diagram I posted has 3 nipples to connect hoses. Nipple #1 at the top of the TB points to the firewall as does nipple #2 at the bottom of the TB. Nipple #3 at the bottom of the TB points toward the front of the car. Which nipple # has the bolt in the hose? Can you post pictures of the other nipples and also assign #s to them.
Old 01-15-2015, 08:12 PM
number 3 has the bolt. On mine it points to the passenger side. Ill take better pics and put numbers tomorrow
Old 01-16-2015, 05:45 AM
Fish Twig
tony_2018's Avatar
Thats not where it suppose to go. That FITV hose needs to go to the head and not where you circled it on the intake manifold.
Tried to upload a picture of where I'm sure its suppose to go but its failing on me. If you look at Ron's image upload look closely at where the UPPER radiator hose goes you'll see a nipple there. Can you verify that on your engine setup?
Old 01-16-2015, 10:09 AM
92ehatch's Avatar
What throttle body would that be then? His definitely has an fitv on it
Old 01-16-2015, 10:31 AM
Maybe I missed something. Where did you see a FITV in the picture?
If a FITV is present on the TB, then the OP's B16a2 is not stock.
Old 01-16-2015, 11:21 AM
This one picture should show you where the bottom hose off the throttle body goes. there should be a nipple next the the hose that goes from the thermostat to intake manifold but there isnt
Old 01-16-2015, 11:27 AM
I know exactly where its supposed to go. the nipples i circled are the exact one the Reff had highlighted on the diagram he gave me. concidering hes the CA smog Referee i trust him but there is no nipple where he highlighted.
Old 01-16-2015, 11:32 AM
you can see the bottom 2 hoses coming off the throttle body. just under my air intake you can see the second
Old 01-16-2015, 11:55 AM
Fish Twig
tony_2018's Avatar
That area you keep showing me is where the lower radiator hose goes, take a picture of the upper radiator hose connecting to the head.
Old 01-16-2015, 11:56 AM
Fish Twig
tony_2018's Avatar
Ron see image. I'm sure thats an FITV.
Old 01-16-2015, 12:01 PM
Fish Twig
tony_2018's Avatar
You're probably running all kinds of non obd2 compliant anonymous parts on that car because a b16a2 does not have an FITV. I'm surprise your ref didn't point that out. I mean he is a certified CA ref so he should be the almighty god of obd2 compliantness.
Old 01-16-2015, 12:40 PM
Old 01-16-2015, 12:51 PM
Fish Twig
tony_2018's Avatar
Whats the engine code?
Old 01-16-2015, 01:00 PM
Fish Twig
tony_2018's Avatar
Ron, looking at your image of the thermostat housing and comparing it to Honda oem parts site I see some differences.
Old 01-16-2015, 01:04 PM
Fish Twig
tony_2018's Avatar
Look at my attached image and you should see where the hose is suppose to go. Unfortunately you seem to have an automatic b-series throttlebody on there, not sure why. But if you route it correctly following my diagram below you should be fine.
AS TO WHY YOUR NIPPLE LOOKS SAW OFF I have no clue. but that is the way its suppose to be routed, From throttlebody to the upper radiator hose
Old 01-16-2015, 01:16 PM
That looks like it. Thanks
Frozen E
10
04-04-2011 09:11 PM
prelude_93vtec
06-26-2007 06:30 AM
FG Two
06-14-2005 10:12 AM
Quick Reply: throttle body hose
