B18A1 engine swap into 93 Civic
Just picked up a 1992 Integra with a B18A1 and was hoping to swap it into a 1993 hatchback. Any suggestions on whether or not this will work or will be with it?
Re: B18A1 engine swap into 93 Civic
This is definitely a do-able swap.
As mentioned before there is a bunch of information in the FAQ section.
This is a good place to start.
https://honda-tech.com/honda-civic-d...el-sol-983454/
for the most part should be plug in plan since both are obd 1, you may need to cap so vaccum ports as b18a1 had a lot of vaccum stuff that the 92-95 and 94-01 tegs didn't have.
The big issue is you are going to need to convert the trans to hydro or just get a hydro LS trans
also believe all the mounts are different.
IMO it would be easier\better to sell the swap and by a 94-01 LS swap
baller78c4life
12
10-26-2005 10:11 AM
