Spare Tire Area Leak.
Old 01-08-2015, 01:19 AM
RuckRider2's Avatar
Default Spare Tire Area Leak.
hi im wondering if any of you guys have this kind of leak? i know its common for civics to have a tail light gasket go bad on them. i replaced them recently and i dont see any leaks coming around the taillights when my buddy sprays water on them. its a 00 civic coupe. i've checked the sunroof drain tube and its not leaking from there also the white bumper clips on both sides were leaking so i sealed them(minimal leaks now). when i pour water on the trunk i dont get any leaks even the spare tire well is dry only when i run the car in the rain where i get leaks. im not sure where its coming from? i also checked the bumper vent and its not leaking from there either. im running out of ideas where it could be coming from. possible underneath the body?
Old 01-08-2015, 03:21 AM
92ehatch's Avatar
Default Re: Spare Tire Area Leak.
When you pour the water are you in the trunk?
Friends with garden hoses and you in the trunk is the best way to find it.
There are also plugs in trunks that can leak water when you are driving but only when you are driving. If this happens when the car is sitting then they are not the issue
Old 01-08-2015, 06:04 AM
ejv8s10's Avatar
The rear window may be leaking into the trunk.
Tape it up and hose it down to see if the leak is gone.
Old 01-08-2015, 12:49 PM
belairbrian's Avatar
I lean toward 92ehatch's idea.
I had a 280z that got wet floors when driving but not when sitting in the rain. Finally found a rubber body plug with a crack in it. Water spraying under the car pushed through it but sitting still it couldn't.
Old 01-08-2015, 03:31 PM
RuckRider2's Avatar
yeah im inside the trunk while my buddy poured water on the trunk and window area i fixed the leak coming fromthe white bumper clips and stopped leaking now and i only get the leak when im driving. where are these trunk plugs you speak of? i shall find it!!!
Old 01-08-2015, 03:32 PM
92ehatch's Avatar
They are in the trunk. Under the sound deadening material. Take out the spare
Old 01-08-2015, 03:34 PM
92ehatch's Avatar
Also take out the inner trunk linings and look into the fender Wells for water. Could be tire spray coming in that way. Any rust in there would be a sign
Old 01-08-2015, 03:40 PM
RuckRider2's Avatar
i have to peel off the sound deadening? or i can just seal it with a sealant from the outside(underneath)
Old 01-08-2015, 04:29 PM
92ehatch's Avatar
My suggestion is. Take out spare and trunk lining. Dry up everything. Next rainy day set out on an adventure..preferably with the cat..the cat in the hat.
Pull into a dry area and inspect where water is. It will leave a trail
Old 01-09-2015, 12:09 AM
MisereNoire's Avatar
Check the body seams that run from the rear windows at the corners to the trunk opening lip, and at the outer corners of the trunk. They commonly develop fractures after this many years. Here are a few pics of mine after i repaired them.
Old 01-09-2015, 01:11 AM
RuckRider2's Avatar
yup ive sealed those cracks even the one on the top weather stripping where it meets the rear windshield. the leaks arent running thru the side of the body tho like its only at the spare wheel area no traces of it coming from the side and from the tail light and its only when when im driving in the rain but when it sits while raining its dry.
Old 01-09-2015, 10:58 AM
Loves Tossing Salad
09chaplak's Avatar
Old 01-09-2015, 10:19 PM
Retired Moderator
EsotericImage's Avatar
Theres also 2 areas as you look into the trunk, put your head inside around the inner tail light areas.
Theres 2 round plastic caps about the size of a nickel that sometimes crack and fall out. Thats where i found mine was leaking. Just have to poke around and find it.
Old 01-10-2015, 02:15 AM
RuckRider2's Avatar
theres one on each side? or both on the same side? is it near the bumper vents?
Old 01-10-2015, 02:19 PM
RuckRider2's Avatar
Now my problem is that the trunk area gets wet ONLY when im driving in the rain but not when im parked while raining. so im guessing theres water going in through the under body of the trunk and underneath the sound deadening and to my spare tire well.
Old 01-10-2015, 02:51 PM
92ehatch's Avatar
In your first picture. The plug we speak of is right under your text.
I still think its coming from somewhere else
Old 01-12-2015, 12:24 PM
RuckRider2's Avatar
after a few days of riding in the rain NO WATER IN THE TRUNK!!!! mybe a drop of two but i think it came from the trunk when i opened it. FIXED!!
Old 02-05-2016, 03:55 PM
simjosh's Avatar
PO of my car had drilled out the truck to keep water from coming in but a couple of the holes ALLOW water to pool.. so be careful if you drill holes in the tire area
pezzy
03-04-2010 05:05 PM
4DRmafia
04-25-2007 09:57 PM
Wiseguy619
11-11-2006 03:49 PM
scyked
04-12-2006 03:45 PM
.ShawnD.
04-26-2004 10:33 AM
Quick Reply: Spare Tire Area Leak.
