Idle stops and goes
Idle stops and goes
Car is a '93 Civic DX with a D16Y7 and AT.
Car starts up fine and the idle is good at that point. If I drive it around for around ten or so minutes, stop, and shift to park the idle issue shows up. I tried cleaning out the IACV but it did nothing. Video of the issue as it will explain things way better than words. I have work in about three hours and it's a bit rainy at the moment but I'll try all advice when the weather allows it.
Re: Idle stops and goes
Forgot to mention it's not guaranteed to idle like that every time. Just went for a drive and it only made that idle stop once then it idled normally.
is
Its under the intake manifold with a hose coming from the black box.
I have a question.
You have a y7 in an obd1 car
did you swap it or buy it that way?
How was the wiring done and what ecu do you have
Is your catalytic converter on the manifold or under the car
I have a question.
I bought it that way last August. Was swapped by an older guy who owns quite a lot of Hondas. Sadly I neglected to get the rest of the information.
CEL does indeed work. When I went to get my distributor rebuilt a code showed stating a fuel plug was loose so fixed it. Cooling system hasn't been bled. I went on a drive safter the ECU reset and the idle issue hasn't showed up. I deliver pizza so if it's still there it will show up while I'm working.
Does the air filter sit on top of the throttle body indicating factory y7 intake manifold or does it sit at the passenger head light with the long intake manifold like stock
So you have the factory for your cart intake manifold and exhaust and the only thing from the y7 is the motor andpossibly transmission.?
This is important as far as wiring concerns and sensors/idle control valves.
If this is correct then my first suggestion is to take off the fitv on the bottom of the tb clean it and screw the plunger back in. this can help eliminate it as a source of vacuum leak.
Also now the pcv is on the manifold between the runners
TurboSI24
11-23-2005 03:39 PM
