[Suspension] What is the cause of this? EG Hatchback
Old 01-22-2015, 07:33 PM
Frany's Avatar
Icon3 [Suspension] What is the cause of this? EG Hatchback
SOLVED it was the bump stop plate that was missing
Just got done putting Tein S.Tech Lowering Springs on my SHS Shocks
the rear is fine but the front has the top of the shock sticking out where it shouldn't.
This is on a 93 hatchback.
Please tell me what I did wrong and how I can fix it.
Thanks ahead of time.
Old 01-22-2015, 07:48 PM
Former User's Avatar
Default Re: [Suspension] What is the cause of this? EG Hatchback
The diagram shows the stock strut. Are you missing the dust cover plate and damper mounting rubber?
Old 01-22-2015, 07:53 PM
Frany's Avatar
Thank you for your quick and helpful reply.
I'm missing the dust cover plate.
Will reinserting in solve the issue?
Old 01-22-2015, 07:57 PM
It should.
Did you use a spring compressor? See second diagram.
Old 01-22-2015, 08:05 PM
Frany's Avatar
Originally Posted by RonJ@HT
It should.
Yes I did. Thank you I'll try that.
Old 01-23-2015, 06:03 AM
Fish Twig
tony_2018's Avatar
Bump stop plate.....my assumption.....you'll need that.
Old 01-23-2015, 12:33 PM
Hysterically Calm
TomCat39's Avatar
Looking at the picture and looking at the stock strut diagram it looks like the bump stop plate and the bump stop are above the damper mounting base (plate).
Looks like the strut parts were re-assembled out of order.
The bump stop and bump stop plate must go on before the damper mounting base.
At least that's what it looks like to me.
Old 01-23-2015, 02:03 PM
Fish Twig
tony_2018's Avatar
Looking at the diagram again, she's missing dust cover plate, dust cover, bump stop plate and probably the bump stop if its not on there. Those are necessary, who ever helped you with this sure as hell did not understand how parts work.
Old 01-23-2015, 02:09 PM
Originally Posted by tony_2018
Looking at the diagram again, he's...
He may be she.
Old 01-23-2015, 02:23 PM
Fish Twig
tony_2018's Avatar
He may be she.
Yes sir...I'll edit.
Old 01-23-2015, 02:34 PM
She may be he.
Old 01-23-2015, 03:28 PM
Hysterically Calm
TomCat39's Avatar
He may be she.
She may be he.
This gave me a good chuckle....
Old 01-23-2015, 03:30 PM
I hope tony knows I was just goofing around.
Old 01-23-2015, 04:28 PM
Fish Twig
tony_2018's Avatar
He or she, dont matter. All members.
Old 01-23-2015, 07:05 PM
#1 Super Guy
94eg!'s Avatar
It is the BUMP STOP PLATE that is missing. Period. The dust cover and dust cover plate do nothing to control the damper rod. If you tried to use them WITHOUT the bump stop plate, the step in the damper-rod would punch right through the hole with the first bump in the road.
It's the bump stop plate that controls the damper in compression. It's the damper mount washer that controls the damper in rebound. The rubber bushings are there to allow the damper to pivot relative to the top hat. The dust covers simply help protect the polished rod & cylinder seals from the elements.
Old 01-23-2015, 10:24 PM
Hysterically Calm
TomCat39's Avatar
Yes, we know the bump stop plate is what keeps the unit from shooting through the mounting plate.
In the picture, that metal disc on top looks like the bump stop plate. But I guess from what you are saying is it's the dust cover plate and there is another metal plate (bump stop plate) that goes on of that dust cover plate but under the mounting plate.
Old 01-23-2015, 11:47 PM
Fish Twig
tony_2018's Avatar
Actually what you're thinking that its the bump stop plate IS NOT THE BUMP STOP PLATE. That is the damper washer.
Old 01-24-2015, 07:40 AM
#1 Super Guy
94eg!'s Avatar
According to the OEM parts description: 1994 Honda Civic 3 Door CX KA 5MT Front Shock Absorber
#14 is bump stop plate
#6 is shock-absorber washer
#9 dust cover plate
Hysterically Calm
TomCat39's Avatar
Thus 93EG! is dead on, what's missing is the bump stop plate to keep it together properly.
It's not assembled out of order but quite likely missing parts altogether.
I follow now. Thanks.
Old 01-25-2015, 10:49 AM
ozh_hawaiian's Avatar
same thing happened to me the first time I changed my suspension lol! you got one of the washers in the wrong place... learning lesson
Old 01-25-2015, 02:22 PM
Oh look, I can change this
deschlong's Avatar
From a post of mine. Gives a good visual.
Originally Posted by deschlong
Here is a breakout diagram of a stock Honda Civic / Acura Integra front strut.
Part terms are as follows (to help other n00bs):
A. Strut
B. Bump stop
C. Tapered bump stop washer
D. Strut dust cover
E. Dust cover top washer
F. Top hat lower bushing
G. Sleeve (allows top of strut to pass through bushings)
H. Top hat
I. Top hat upper bushing
J. Top nut washer
K. Top nut (screws on to top of strut)
L. Spring
Old 01-26-2015, 09:22 AM
Think the OP is missing part C... im pretty sure that's the part I forgot to put in...
Old 01-26-2015, 11:30 AM
Frany's Avatar
Thanks for all the replies everyone.
I fixed this right after Ron Posted the diagram.
As always its the small things that matter the most. It was the Bump Stop Plate.
Put it back in and everything sits and works as it should. ..Easy to forget the little thing.
I recommend these tein springs to anyone looking for a decent drop and great ride quality without spending too much.
Evo2EK4
05-02-2010 03:04 PM
just rave
11-13-2007 12:55 PM
Drew17th
Suspension & Brakes
01-29-2007 08:34 AM
Lookincrazy
04-19-2002 08:45 PM
Lookincrazy
04-19-2002 07:31 PM
Quick Reply: [Suspension] What is the cause of this? EG Hatchback
