97 del sol - D15b7 engine swap and auto to manual
Old 01-18-2015, 06:27 PM
splashy's Avatar
Default 97 del sol - D15b7 engine swap and auto to manual
I have a 97 del sol automatic with d16y8 that needs a new engine. I have 2 questions, first I bought a complete d15b7 with manual transmission on cl that was very cheap. Will this be a direct fit to replace to old d16y8? And second how much extra work would it be to change from auto to manual trans since it came with the trans anyways and the old auto trans had 300k on it
Old 01-18-2015, 06:31 PM
Former User's Avatar
Default Re: 97 del sol - D15b7 engine swap and auto to manual
Did you check your state laws about swapping on older engine into a newer car?
Old 01-19-2015, 09:44 AM
H0nda_Crazy's Avatar
goes out and buys a whole new engine and tranny without knowing if it will swap.............genius..........Should've done your homework bud...
Old 01-19-2015, 10:01 AM
Fish Twig
tony_2018's Avatar
There are guides that show you how its done. The difficulty level will vary depending on your ability to understand wiring and custom work needed to be done.
Old 01-19-2015, 12:27 PM
splashy's Avatar
HA I didn't really need a lecture, just wanted some info if it was a direct fit. I actually have three other del sols with d15b7 engines so I figured why not buy it for 100$. Just thought if it could go right in and replace the d16y8 it would work out good.
Old 01-19-2015, 12:41 PM
Fish Twig
tony_2018's Avatar
Any ****** d-series from 92-00 will be capable of being swapped into another d-series 92-00. The issue here is the auto to 5spd swap dumb ****.
RobocracyAlpha
14
11-09-2015 10:39 AM
ek9.5
07-23-2013 02:30 AM
TeggieeTuner
02-20-2008 07:38 AM
I Have an STD
10-22-2003 05:35 PM
Quick Reply: 97 del sol - D15b7 engine swap and auto to manual
