00 Civic/b16a2 swap in limp mode
Old 01-19-2015, 01:46 PM
The Neutron's Avatar
Default 00 Civic/b16a2 swap in limp mode
Hi i have a 2000 honda civic with a b16a2 swap. I had first started noticing this after i had filled up the tank yesterday. The car seems kinda sluggish. It takes longer for the rpms to go up and when i hit Vtec i can feel the car slow down. I had put octane booster in the tank and that helped a little but not really. I also checked the Vtec solenoid screen and it was clean. My next guess would be fuel filter is clogged and is restricting fuel flow. Any other ideas?
I have a few engine mods. Type R cams, headers, cold air, lightened flywheel and stage 2 clutch.
The Neutron is offline
Old 01-19-2015, 01:51 PM
ejv8s10's Avatar
Default Re: losing power when Vtec engages?
If it is related to the last tank of gas, yes consider the fuel filter or contaminated gas.
Also consider the fuel pump, which would be coincidental to the last fill-up.
ejv8s10 is offline
Old 01-19-2015, 02:05 PM
I never narc'd on nobody!
NotARaCist's Avatar
Full details on the swap. You need to give them to us. What ECU are you using? What transmission? What the swap known working before you put it in? Compression test? Spark color? What fuel are you giving it?
NotARaCist is offline
Old 01-19-2015, 02:15 PM
The Grumpiest
grumblemarc's Avatar
Does it throw a CEL when it happens?
grumblemarc is offline
No CEL. Its not the swap. Its been running fine since i got the car. I have a p2t ecu along with a 5 speed. I have a few engine mods. Type R cams, headers, cold air, lightened flywheel and stage 2 clutch. But the car was running fine 3 days ago so im thinking it had to be fuel related or maybe my Vtec solenoid is bad? I had put 87 octane in it but today i had put octane booster so i should be fine octane wise
Old 01-19-2015, 02:18 PM
When i hit Vtec it also seems to be a little louder than normal but i think i have a small exhaust leak
Old 01-19-2015, 02:44 PM
NotARaCist's Avatar
Well, the 99-00 SI calls for premium, so there's a problem right there. Why are you feeding it 87 when it calls for 91?
Old 01-19-2015, 02:50 PM
I didnt know it recommended 91 but with the octane booster im at around 100
Old 01-19-2015, 02:59 PM
The Grumpiest
Bullshit. Octane booster doesn't make up that much of a difference.
Old 01-19-2015, 03:10 PM
NotARaCist's Avatar
From 87, to 100?
bahahahahahaha no, no you aren't. Even if you were pouring pure ethanol in there, you aren't at 100. Straight ethanol has an AKI octane rating of 99.15, in case you were curious. ****, even if you were pouring 110LL in there, you've had to put like, 2 or 3 gallons of it in your tank.
Still. Ive ran 87 in it before and had no problems so i know octane isnt the issue
Old 01-19-2015, 03:36 PM
NotARaCist's Avatar
I asked you 6 questions. You answered 3. If you expect to get help, you'll need to answer all questions asked of you. While we're at it, I'm going to add a 7th and 8th question to the pile. I'll even post them again, so you can't use that as an excuse.
And the new questions: What is your fuel pressure? Have you checked your timing?
Old 01-19-2015, 03:41 PM
Im not exactly sure on the transmission. I had bought it already swapped. He said gsr trans. I havent done a compression test. I dont know what you mean by spark color but my plugs are clean and gapped correctly. Did my timing today. Its at 18 degrees. I dont have a fuel pressure gauge. As ive said before though it ran fine 3 days ago so i dont see how trans would matter.
Old 01-19-2015, 03:50 PM
NotARaCist's Avatar
It's called full information. Here's a bit of advice for you. When you come to people asking for help, don't just dismiss questions because you don't think they're relevant. You came to us because we know more. If we're asking a question, there's a reason for it.
Spark color. What color is the spark emitted from your spark plug? You are the first person who didn't understand that question.
Why did you set timing to 18 degrees? Spec is 16. That would also explain your power loss.
Set your timing to 16*, where it belongs. If that doesn't help, then buy/borrow/rent a fuel pressure gauge, as well as an HEI/DEI spark tester.
Old 01-19-2015, 03:56 PM
Im young so i dont know everything. Ive never even heard of spark color till today. I tried getting it as close to 16 as i could. Only reason i adjusted the timing was because i had to go to the smog reff. Its says plus or minus 2 degrees so i figured 18 was close enough.
Old 01-19-2015, 03:57 PM
NotARaCist's Avatar
Why could you not get it to 16?
Old 01-19-2015, 04:02 PM
I just wanted it between plus or minus 2 degrees to pass the ref. Im doing it now but the car has to warm up again
Old 01-19-2015, 04:16 PM
Timing is at 16 degrees
Old 01-19-2015, 04:22 PM
The Grumpiest
And?
Old 01-19-2015, 04:29 PM
Still seems sluggish and power drops at Vtec
Old 01-19-2015, 04:33 PM
Fish Twig
tony_2018's Avatar
Take it to a dyno so we can see the powerband on the chart instead.
tony_2018 is offline
Old 01-19-2015, 04:37 PM
Im in a small town so dyno wouldn't be a easy thing. Im probably just going to drive till my tank goes empty and fill it with 91 and see if that fixes it. If not ill run the fuel pressure and compression if i can borrow or rent the tools
Old 01-19-2015, 04:55 PM
NotARaCist's Avatar
So, if your approach to timing is any indicator, there's a lesson you need to learn before it costs you a motor. "Good enough" isn't good enough. When you're working on something, get it as close to perfect as you can.
Old 01-19-2015, 05:15 PM
Fish Twig
tony_2018's Avatar
Running type r cams, no premium gas but got octane booster, stock ecu. equals the unknown. Get a video of this engine running in vtec.
Old 01-19-2015, 05:22 PM
Quick Reply: 00 Civic/b16a2 swap in limp mode
