98 civic lx wont turn sometimes (solved)
I have 98 civic...it works fine just bought new dizzy....so has new rotor and cap...its runs good..sometimes it just wont turn on it will crank up...i have gas and everthing...i also bought new rywire jumper hanrness since i tought it was the ebay one... Has anyone expirince thi beforee need helpp...
Thanks in a advancee
I never narc'd on nobody!
re: 98 civic lx wont turn sometimes (solved)
Car information
For all technical questions, the following information MUST be included in the first post: vehicle (year, make, model) and engine (if not stock, year, make, model, OBD type). Other pertinent information includes check engine light (CEL) codes as well as engine modifications, such as a turbo kit tuned at 18 psi or a specific throttle body, large injectors, big cams, etc. This information is absolutely essential because, in many instances, members wishing to help in a thread waste their time by posting detailed replies, only to find out the next day that the topic starter left out CRITICAL information. Please respect members wishing to help by taking the time to list or mention crucial information about your car.
I'm not sure why you think the rules don't apply to you. If you're using a jumper harness, there's obviously something you aren't telling us.
Alrighty, now let's move onto step 2 from the stickies, that you decided not to read.
https://honda-tech.com/honda-civic-d...2A%2A-1992733/
There is spark ..couse it turns on normal Like no problemm...fuell.. yes i do have fuel running ...timing is good.. Im thinking it can b the new distrubitur that is bad..?
I had the same prob bro. Check to make sure your inner tube seals arent bad.
PULL out the spark plugs and make sure they are DRY. Wet plugs wont ignite.
either the inner tube seals are bad or a fuel injector is leaking.
For the love of mother f'ing god, OP check the diagnosis 101 link and do some proper tests before coming here and mouthing off all the **** you think is right with your car.
How do you know you are getting spark? How do you know you have proper fuel? What the **** is "won't turn over", is that supposed to mean the engine doesn't crank or doesn't run?
I don't know how some people make it through life...
^ yeah your right. im just giving him a break. who knows maybe that would help him though like i said i had the same issue and that was the solution
I'm not really trying to be a dick towards you, its just these guys come in here asking for help and they refuse to help themselves or even do the bare minimum to fix their issues.
Its cool man i get where you are coming from. Everyone should do their own research prior to coming in here. either way being stuck on your vehicle sucks and i hope this guy gets it running smooth.
my bad coming here with not enough info its just its my daily ..and iknoe my car... Well to know if i have spark and fuel...but i found out what it was incase anyone has the same problem...so 96-00 i think the honda civic has a bad ignition switch problem ..u can see it on honda.com in recalls..i went out and replace mine with autozone parts cost me like 50 bux.. And it work it wont tur off no more or anythingg..! Thankss tho guys ... Sorry for not coming here with more infor known i knoee
BigDuy01
07-08-2022 09:26 PM
josepagina
08-02-2013 10:44 AM
