1995 Honda Civic Fog lights
I just bought a 1995 Honda Civic EX with a after market fog lights installed. I can't find the toggle switch for it to turn them on! I asked the previous owner and he doesn't know either! Can anyone point me in the right direction where it could be located?? I've looked under the steering, around the dash and even underneath...
Re: 1995 Honda Civic Fog lights
Well, the standard location for the switch was a push button type in either one of the two button clusters either side of the steering wheel on the dash face...but there could be a switch on the console next to the parking brake handle...if not there, you need to find the fog light wire harness starting at the light fixtures and trace your wires back to the cab. then you'll know for sure. Some folks just install them for looks and not function.
If no switch, its possible they were wired onto the headlamp/parkinglight switch, or possibly its wired onto an option connector where that option connector is live when ignition is alive and the bulbs are just burnt out. As mentioned above, trace the wires, check fuses found along the way.
Ok.. update! I found that fog light were just for looks.... how lame! Will have to test them and see if they can function at all.
Thanks all for the help!
Silvertune
11
04-15-2012 09:20 PM
kay_animation
05-03-2003 05:31 PM
