honda civic ej9 2000 not starting injectors not firing
Old 02-03-2015, 12:56 PM
rabesi's Avatar
Default honda civic ej9 2000 not starting injectors not firing
hi there, having problems with my 2000 ej9 1.4 not starting what iv checked so far:
got spark, got fuel to rail but nothing coming through any of the injectors.
the question is what holds these out? and how do i check them?
i thought it was the main relay? but changed it for one i had lying about and still nothing
does the immobilizer hold the injectors out?
thank in advance for any help
Old 02-03-2015, 01:11 PM
turbohatch96y7's Avatar
Have you checked for 12v at the injectors?
Old 02-04-2015, 06:38 AM
rabesi's Avatar
Default Re: honda civic ej9 2000 not starting injectors not firing
hi thanks for the reply, yes im getting 12v between each injector and earth, so its like its not getting a signal from the ecu to pulse
another thing my green key light keeps flashing when i try and start it not sure if that has anything to do with it but i assumed the immobilizer cut the fuel pump
Old 02-05-2015, 11:10 AM
rabesi's Avatar
anyone?
Old 02-05-2015, 02:21 PM
HOMEMADEPOWER's Avatar
Check to see if your fuel injection relay is still good
Old 02-06-2015, 09:10 AM
rabesi's Avatar
the main relay? if so yes i swapped it with a known working one or is there another relay that controls the fuel injectors?
Old 02-10-2015, 06:38 AM
rabesi's Avatar
anything else i can check?
Old 02-10-2015, 11:43 AM
Former User's Avatar
Is the 2000 EJ9 ECU OBD2a or OBD2b?
Old 02-10-2015, 11:46 AM
rabesi's Avatar
obd2b
Old 02-10-2015, 11:51 AM
Turn key OFF.
Unplug ECU connector B.
Test for continuity to body ground at these connector pins:
B2, B10, B20, and B22
Old 02-10-2015, 11:57 AM
rabesi's Avatar
ill carry out those checks in the morning and report back, thank you very much
Old 08-20-2021, 06:47 AM
Help me honda's Avatar
did you ever fix the car I'm havimg these identical issues?
tundra2000
06-16-2010 08:46 AM
tundra2000
06-09-2010 06:33 PM
Mr.Highlife
12-07-2009 05:53 AM
slamedcivic
11-02-2006 01:49 PM
EGHatchy
07-14-2002 11:25 AM
Quick Reply: honda civic ej9 2000 not starting injectors not firing
