97 Civic HX passenger door lock problem!
So i have a 1997 civic and for the first time I came across this problem.
Sometimes my passenger lock will lock when I press the manual lock button on the driver side door, but if i use my keyless entry alarm button to lock the doors, the passenger side doesn't seem to lock anymore. It was working just fine but now its developed some sort of problem. Im not to sure about, any help?
thanks in advance!
thanks in advance!
Re: 97 Civic HX passenger door lock problem!
The metal rods that connects the power lock solenoid and lock you press is sliding on the joint/connecting point. Tighten the screw (red) so that the both rods are firmly joined.
i looked in the door panel and couldnt find the screw your talking about, are you sure thats for a 97 civic passenger door? I tried to find anything i could tighten but i found nothing.....
i dont no why it wont lock nothing looks broken and i just changed the window regulator a year ago
I never narc'd on nobody!
That's...that's not stock, at all. I don't know where you got that, Heisenberg, but you're way off base.
The window regulator is not the lock regulator. Different parts. It might just be on it's way out. As RonJ said, test it.
xkitex
07-12-2012 06:47 AM
PunkRudeBoy
10
06-07-2011 04:03 PM
97 CRV: Power door locks, all 4, cycle when the close button is hit, repeatedly trying to close, not
SteveW
02-21-2007 01:48 PM
