OBD2B swap in OBD2A car
Hey guys, I have an automatic 97 civic ex and the motor is knocking, I bought a 99 automatic civic ex for cheap with intentions of swapping the motor to the 97 shell. I'm running into the problem where the 97 is OBD2A and the 99 is OBD2B obviously. Could I just drop the OBD2B motor in the 97 shell and call it good or do I need to make some changes and actually run the OBD2A ECU and harness? I'm not looking for which is better, if it were my car I'd run OBD1 conversion and do a manual swap. Please help, I need to know what problems I'll run into before I drop the motor in. Thanks feel free to ask questions!
Crazy Honda Guy
Re: OBD2B swap in OBD2A car
The engines are the same!! They even use the same distributor. Swap the engine in the newer car, use the original harness of the newer car, everything will plug in fine
Technical Hero
The distributor won't plug and play, reuse your cars original one. Also the 96-98 02 sensor is in front of the engine and the 99-00 is before the cat, just reuse your exhaust manifold for ease of install. The rest should be plug and play.
Crazy Honda Guy
What's different about the obd2 distributors? i have both sitting in my garage, never really looked at them, thought they are the same?
I know that obd1 distirbutors are also the same except have two plugs instead of one, and can be repinned using the exact same colors, takes ten mins to do, as i have done it on b series
-update- i went and checked those dizzy's, both one plug, but different style, you are correct. Easiest to just reuse the original one with the car it's being swapped into
My main problem that I can see is, on the OBD2A motor harness there is an extra plug on the drivers side goin into the cab. I have the complete 2B swap, harness, ecu everything. Can I just put it in the 2A shell and be fine? I'll take pictures of the plug I'm talking about tomorrow, just not sure what it would go to. Thanks for the replies everyone
Crazy Honda Guy
I'm going the opposite direction as you. I'm putting in a complete 1997 obd2A engine with 50k original into my 2000 civic sedan with a blow engine. All I'm doing for the swap beside a couple refresh parts is swap over the engine harness, dizzy, and intake manifold. The engine itself is the same, so should be a straight forward swap, and plug & play
Technical Hero
Can't use the OBD2B engine harness in your OBD2A car, it's not compatible with your cabin harness.
No don't swap intake manifolds, yes they differ but only mechanically not electrically and the FIA system he's talking about is self contained so it won't interfere with your OBD2A system.
As for the distributors here's some pics
ohsnapzafingcu
21
11-12-2008 02:22 PM
ITR1071
09-15-2002 09:09 PM
