B16A2 loss of oil
Old 03-31-2015, 01:39 PM
slicrick's Avatar
Icon6 B16A2 loss of oil
Hi. I didn't see any EL specific sub-forum so I thought the 92-00 Civic forum would be the best place to post this, I mean the EL is really just a Civic and the drivetrain that is in mine is used in a lot of cars relevant to this sub-forum. I really wanted an EM1 but every local one near me was trashed and this car came up. I knew the seller personally and got a very good price on the car.
I have a 99 Acura EL with a B16A2 swap. Unconfirmed mileage on the swap the car has 212,xxx kilometers, however, it appears to be recently rebuilt the internals looks next near to new. Runs and drives excellent.
I just recently bought the car (love it so far) it has been a little over a month now and I notice it appears to be losing oil. It does not appear to leak, or at least I can't see it where I park the car so I believe an external leak like an oil pan gasket etc is not the problem. The coolant is good and there is no oil in there.
I had someone in the car while I was behind it and not a hint of blue smoke or any smoke for that matter, no scent of any fluids burning either.
I understand it is very common for the B series engines to use oil but this seems a little excessive, I top it off and in about a week maybe a little longer I am sitting at half full or just over. That is while just driving the car to school/work not driving hard or anything.
The 2 things I thought may be the culprit are:
1. the spark plug tube where the wire/boot attach to the plug has a small amount of oil in it in Cylinder 1 I cleaned it off with a rag and it does appear to come back. Cylinder 2, 3 and 4 are all dry and stay dry. Valve cover gasket maybe?
2. PCV valve?
Thank you for taking the time to read this, I appreciate your opinion and input.
Old 03-31-2015, 04:06 PM
joey1320's Avatar
Default Re: B16A2 loss of oil
So you are losing about 1.5 quarts a week? Or do you mean halfway on the dipstick mark, which will be about 1/2 quart?
How's your driving technique?
Have you done a compression check?
Old 03-31-2015, 04:32 PM
slicrick's Avatar
Sorry, I should of clarified that. Halfway on the dipstick mark. I am driving it very conservatively right now as I don't want to drive the car hard while it has some sort of problem, especially to do with oil loss. I have not done a compression check, I plan to when at a friends shop.
After I made this thread I did notice there was a small wet spot that appeared to be oil, this is the first day its been dry in a little while but I had not seen any oil residue or rainbows where I parked before while it was wet. Soon I will get the car in the air and check the condition of the oil pan and gasket.
wickedmaniac
03-29-2014 10:39 PM
Creepsjr
04-25-2012 10:52 AM
josejdm
04-09-2010 04:38 PM
abdulmo86
10
02-05-2007 05:50 PM
jamal-188
04-10-2002 06:16 PM
Quick Reply: B16A2 loss of oil
