shifter linkage issues
my shifter is really sloppy and i found it to be the riviots on the joint ( what ever its called) by were it hooks to the tranny to be very sloppy is the d series and b series the same i have a 2000 civic ex with a si b16 engine and b16 tranny or is there a way to fix the worn out joint
Re: shifter linkage issues
I had the same problem on my 2000 EM1. The bushing connected to the tranny was absolutely destroyed causing some pretty big movements during shifting. I replaced the bushings and it fixed the problem completely. My lower torque mounts and motor mounts were bad as well... you may want to check all of them out. I haven't replaced the motor mounts yet but the torque mounts really made another huge difference when I changed them.
blasterman87
10-23-2009 05:45 PM
themunchkinman
04-05-2008 04:37 AM
gulftiresinc
01-02-2006 02:32 PM
