52308-SR3-000 vs 52308-S04-000 rear sway d-bracket
(1999 civic si)
i just ordered 2 of the #30 (52317-S04-000) for a total of $24.08 from my local honda dealer
totally forgot about #28 (52308-S04-000)
(1998 integra gs)
98 integra gs i pulled from at the junkyard i got:
- (1) #5 52300-SR3-A01
- (2) #7 52308-SR3-000
- (1) #12 52317-SR3-010 (R)
- (1) #13 52318-SR3-010 (L)
- (4) #27 93403-08020-08
- (4) #42 95701-08018-08
do i need to order the d-bracket for the 99-00 civic si (52308-S04-000) or will the ones that i have from the 98 integra gs work (52308-SR3-000)
i'm assuming no because part number is not the same. however, the bolts i have will work because they are the same part number
for anyone interested i ordered blox rear sway bar end links for $35
Amazon.com: Blox Racing BXSS-10101-EL Rear Sway Bar Fixed End Link Set for Acura Integra/Honda Civic/Del Sol: Automotive
i can't seem to find a 13mm hardrace rear sway bar bushing so i'm looking at getting energy suspension Energy Suspension 16.5107 Rear Sway Bar Bushings - 13mm (0.51 inch) Made by Energy Suspension
Re: 52308-SR3-000 vs 52308-S04-000 rear sway d-bracket
The itr does use a 22mm bar don't know why es says it fits unless its a set of different sized bushings. Worst case scenario buy the bushing for the Si from honda. The part numbers from Es elsewhere just show the 13mm size so you will be good with it.
how do you know the d-brackets are the same even though they have different part numbers? i was gonna call my local honda today and order (2) 52308-S04-000 (the d-bracket for 99-00 civic si
I have used integra D brackets on Si subframe mounting plates, actually still do, which I am about to swap out for an asr with itr sway. If you can get the specific bracket you might as well no harm in having the correct part.
The D bracket from the Integra will work just use the 99-00 SI bushing.
The difference in size ( 1mm) only changed the bushing, not the D bracket.
- 52308-SR3-000 is on the left
- 52308-S04-000 is on the right
confirmed, they're exactly the same. what's with differing part numbers?
in my OP the diagram for the 98 teg, i need #8 and #11 part numbers 52312-SE0-000 and 52316-SA5-000
should i order oem or is there an aftermarket one that is harder rubber/lasts longer? i can't seem to find these bushings anywhere except oem
also i was wrong, i believe the roll bar i got off the 98 teg gs is a 14mm bar... not 13. so should i get: http://www.energysuspensionparts.com...p?prod=16.5107 (16.5107 13mm) or: http://www.energysuspensionparts.com...p?prod=16.5116 (16.5116 14mm)
the 14mm one right...?
also i was wrong, i believe the roll bar i got off the 98 teg gs is a 14mm bar... not 13. so should i get: Energy Suspension 16.5107 Rear Sway Bar Bushings - 13mm (0.51 inch) Made by Energy Suspension (16.5107 13mm) or: Energy Suspension 16.5116 Rear Sway Bar Bushings - 14mm (0.55 inch) Made by Energy Suspension (16.5116 14mm)
https://honda-tech.com/road-racing-a.../#post34570328
Function7 10mm Rear Sway Bar Bushing Set (4) F7-F7BRS10 - King Motorsports Unlimited, Inc.
is that what you are talking about? $40 shipped is a bit much for what it is. be much cheaper to go to local honda dealer. but i imagine the metal inserts would be better to tighten up the suspension the way i want
thanks for letting me know about those
also: while reading about these inserts i came across people saying bad things about the blox endlinks i ordered (they were already delivered yesterday) anyone have anything to say about them?
i found this:
also: while reading about these inserts i came across people saying bad things about the blox endlinks i ordered (they were already delivered yesterday) Amazon.com: Blox Racing BXSS-10101-EL Rear Sway Bar Fixed End Link Set for Acura Integra/Honda Civic/Del Sol: Automotive anyone have anything to say about them?
Those metal inserts are needed to use a aftermarket/ 99-00 SI endlink on an integra bar.
I have them in my rear bar. They fit extremely tight, like ******* tight. I was pounding on my sway bar with a mini sledge. There might be cheaper ones out there, but I just spent the money for the F7's.
Don't bother with Blox endlinks...
EDIT:i have no experience with the fixed end links, only adjustables.
okay im just gonna get the f7 metal inserts because I want this rear end built properly. so I'm thinking about returning the blox links. holding them in my hand they seem high quality but idk I don't mind spending the money because this bar is gonna make the car handle so much better in turns. can't wait
I also didn't mention I got the links from the integra. but if I were to use them they need new bushings
buying this now: http://www.buyhardrace.com/product/h...ic-ek9_29.html
I want this bar installed this week!
just called king motorsports F7BRS10 is on back order and the guy said he hasn't spoke to function7 in a while and they havent had them restocked in over 2 months. so it looks like im going with the oem bushing for now at least
the hardrace fixed links are ordered ($62) the blox links are in the process of being returned. just emailed asr seeing if they can get me the metal inserts they include with their kits. if i can't get them from asr idk what im gonna do...
you can't use Integra endlinks anyways. there is no "OEM" bushing.
You can either order straight from F7, or ASR. Maybe another company that stocks F7 parts.
I was talking about #8 and #11 on the integra diagram. pretty sure it converts the big hole on the bar to a 10mm hole too
"Technically" it does convert it but all those pieces are is a rubber bushing. The integra endlink holds it in place but you can't use it because the LCA won't match the mounting area. There is other options that are not as pretty but will work.
http://www.asrparts.com/upgrade
waiting on this to be delivered then i can finally put this bar on
Lateapex89
05-11-2011 09:44 PM
