eg spoiler removal help
Hey guys so im going to install my new spoiler but I dont see how to take off old one, I looked at other posts but im not getting a description like I have, so here is a pic and help me.
Re: eg spoiler removal help
I think it is those four bolts below your red circles. Should come off in 4-5 minutes. Don't forget to unplug. lol Then separating the plastic from the metal is like they super glued it or something.
I didn't have time to dig for you, but here is a DIY link where the removal might be in https://honda-tech.com/honda-civic-d...ing***-642479/
I was confused the first time I looked at mine also. I have circled in green the nuts you need to remove. The wing has the threaded rods inserted in it and you remove these nuts and it pops off real easy. Also, you will have to pop open the brake light hosing (yellow circles) to unplug the brake light wiring. Most after market wings will have threaded inserts in the wing and they want you to line-up the holes and put the bolts through from the outside (where the nuts are now) This didn't work for me. I bought some longer bolts, cut off the heads and inserted the bolts into the wing first so it was just like the OEM design. This way I was able to get things lined-up and used the stock nuts to finish the install. Here's a link to another install. DIY - JDM EG6 Wing install (92-95 Civic hatch) - D-series.org
BobGnarly
04-11-2004 10:45 PM
