Burning oil bad
Burning oil bad
Hi I have a 99 civic ex (sorta)
I need some serious help. It's the first hinda I've owned so I don't know much about them. The previous owner said he had the heads replaced with unknown heads. All I know is the car doesn't have vtec anymore. It has the vtec cylinder sensor thing but it doesnt engage. I replaced the valve cover gasket (kit) yesterday and did an oil change to rid my car of the black sludge it had inside it when I got it just to find out the car had almost no oil in it. (It was full when I bought it a month ago). Noticed anytime over 4000 rpm it dumps white smoke (looking at it through limo tint) behind me. Still does this after oil change and gaskets. What would my next step be in diagnosing this problem. Car has 192,000 on it. Thanks for any help
Re: Burning oil bad
Sounds like 1 or more of your cylinder (piston) rings is shot: Symptoms of Fried Piston Rings - CarsDirect
Here's some more possibilities for excessive oil burn: http://mechanics.stackexchange.com/q...ne-to-burn-oil
Pull your spark plugs and see if they are coated in oil.
Do a cylinders compression test and report back.
Also, if you want try praying + 10w/40 oil conventional oil + a can of this ****: http://www.restoreusa.com/
Re: Burning oil bad
How do I do a compression check? Is that something I need to take somewhere to do? And piston rings seems easy enough to replace just time consuming. Scale of 1-10 how hard to fix?
Fish Twig
Re: Burning oil bad
Rent compression tool from parts store, and follow this guys instructions
https://honda-tech.com/honda-crx-ef-...-test-3014514/
Re: Burning oil bad
At the bare minimum you will be draining all the fluids from the motor, dropping the oil pan, pulling the engine head, all to pull out a piston. Then if you don't hone the cylinder (send the block into a machine shop) replacing anything other than the oil control rings is a moot point.
Since you don't have a compression tester by the sounds, it's highly likely you are missing all the various tools you need to pull pistons and rings.
Re: Burning oil bad
There is something that may be helpful if your rings are just stuck in the lands.
If you are in the states, they ship there and it looks to be well tested to actually soften carbon and such.
LubeControl - LubeControl LC20 is what you are after.
I'm looking to see if I can get the 32 oz bottle and see if it's effective for my oil ring problem that I have on #4.
There is another way too with is Berryman B-12 but that's a bit more involved with bringing the piston TDC, pouring some into the spark plug hole, using compressed air (compressor and valve holder) to push the B-12 around the rings a couple of times after draining the oil etc.
Either way, both of these are cheap to try if you think it's rings, if you think it's valve seals, that's a job in itself and likely something you'd just pull the head and either take it to a machine shop or do yourself once you have gathered a spring compressor and valve seal pliers etc.
Still cheaper than a swap. But the swap will give you more oomph.
Re: Burning oil bad
I want to start looking for a 00 si with a b16a. But finding an untampered one is next to impossible. Plus my 99 e/dx is a piece. Love the civic and looks and everything just have a bad civic to start with. I just need to save take out a loan and sell this heep to get a good one.
Re: Burning oil bad
Pour a can of this **** in there: http://www.amazon.com/Rislone-4447-C.../dp/B00CGRX6RE
I don't see melting plastic to be good for an engine, especially for the long run.
It may work in the short term but I think it may be more detrimental in the long run.
Re: Burning oil bad
I'm not sure I am a fan of that product. Besides the solvents, it is utilizing acrylic polymers to seal the gaps.
Re: Burning oil bad
Oil and coolant, sounds like the head gasket is leaking severely.
Just a guess but you can test for it and confirm.
Re: Burning oil bad
Yeah based on him saying it was more whitish in color i was thinking it had something to do with coolant as well. Maybe you just need a new head gasket??? Maybe sell this B*tch before she gives you to many issues!
Re: Burning oil bad
If you can do it your self get that oem head gasket, and replace ASAP! Make sure not to drive it (unless to repair it)until it's fixed or else you could damage your block. Definitly keep oil and coolant/water on you when and if you do have to drive it. GL bro
