oil light in cluster not working
ok so i have no oil presuure light in my cluster anymore. at first i thought it was the bulb burned out but i swapped it with my engine light and it works fine. could the sensor itself be faulty? does anyone have a wiring diagram of the oil pressure circuit?
Re: oil light in cluster not working
i tried swapping the bulb, unplugging the sensor, and i tested for voltage at the wire going into the cluster, i believe the wire is pin A&
preludedriva
11-30-2007 11:44 PM
