Brake fluid leaking
Brake fluid leaking
Hello there, I have a 95 b18c del sol. It's leaking brake fluid. I checked all the bleeder, visual inspection to see any external leaking but I couldnt find anything. Any suggesion?
Dur Da Dur
Re: Brake fluid leaking
refill the fluid reservoir, get the car up in the air, start it up and pump the brakes. You'll find the leak eventually, just make sure the reservoir stays full or else you'll end up pumping air out of the hole in the brake system and you won't find the leak. That's sort of a 'durrr' moment.
Check where the master bolts to the booster. Pretty common for the master to leak and it runs down the front of the booster under the master. Look for peeling paint on the booster
Steve at Heart
Do you have a flare wrench set? I would tighten or check all of the fittings, lines, bleeders, and proportioning valve.
Some Home Depot's carry this set.
http://www.homedepot.com/p/Husky-SAE...W6PC/203541511
eh9deux
17
06-13-2011 07:33 AM
stripes777
10-28-2006 11:16 PM
