'95 del Sol B16A3-Experienced fuel cutoff at around 7500rpm (before 8200rpm redline)
Old 03-13-2016, 06:09 PM
OldManTSX's Avatar
Default '95 del Sol B16A3-Experienced fuel cutoff at around 7500rpm (before 8200rpm redline)
I don't believe this is normal... What could have caused or be causing it?
Thanks in advance for your input!
Old 03-13-2016, 06:39 PM
Dur Da Dur
hondur's Avatar
Default Re: '95 del Sol B16A3-Experienced fuel cutoff at around 7500rpm (before 8200rpm redli
Check the ECU in the car. IIRC 7500 would be proper for the single cam vtec, or del sol Si.
Old 03-14-2016, 02:35 PM
OldManTSX's Avatar
Hmm... I have a P28. Another surprise and something not disclosed to me by seller.
What reason would the previous owner have for swapping out the original P30 with a P28? Could I have issues running a P28 with the B16A3?
Thanks again for your input!
Old 03-14-2016, 07:32 PM
Fish Twig
tony_2018's Avatar
Most idiots get misinformed, or misinterpret, the idea that a p28 is the BEST ecu. What they don't understand is that a CHIPPED P28 is a good option. So if the p28 isn't chipped and is stock than yes you will need to locate a p30 or chip the p28 with a p30 basemap.
Old 03-14-2016, 08:50 PM
Stancetard Hate Monger
eghatch9295's Avatar
yeah, stay well away from 7500 until you have the correct ecu. unless you hate your engine, then rev away.
Old 03-15-2016, 12:00 AM
OldManTSX's Avatar
Thank you all!
Mr2Rotor
Northeast (Sales)
07-13-2013 08:32 PM
b16_sol_707
Northern California (Sales)
08-11-2008 03:39 AM
polsky's del sol
01-01-2008 10:33 PM
DeadVet
10-25-2004 11:35 AM
KamikazeSol
07-31-2003 08:29 AM
Quick Reply: '95 del Sol B16A3-Experienced fuel cutoff at around 7500rpm (before 8200rpm redline)
