Will B18b1 Axels fit a 93 Delsol SI hub!?
Doing a b18b1 swap into my 93 delsol si.
I counted 26 teeth on the outter side of my d series axel. The side that goes into the hub.
WOuld a b18b1 axel fit into my 93 delsol?
ALso WHAT IS A HALF SHAFT!? Or intermidate shaft. Where is it located? I dont think d series has one but THe B def does.
THANKS!!
THANKS!!
Re: Will B18b1 Axels fit a 93 Delsol SI hub!?
You'll need to use the B-series axles with your swap. They will fit into the Si hub. The half shaft is located on the back side of the engine below the oil filter on the B18B1.
B-series axles are equal lenght and use a half shaft.
D-series axles are unequal lenght and have no half shaft.
You can see the two axles and the half shaft (intermediate shaft).
eH.
eH.
pnoipj89
10-12-2010 06:14 PM
jdm_vtec
08-30-2007 11:57 AM
dustin
10
04-03-2002 12:53 PM
