Burnt ATF: to change or not to change?
Might seem like an obvious question, but this is an argument older than the internet. I acquired a new, fancy beater that may have never had its transmission serviced. Fluid is mostly brown, trans doesn't slip, but does shift a little harder than it should. Due to the horror stories of people flushing their very dirty fluid and replacing it with new, only to have their trans fail quickly, I wanted to ask you guys your opinion. Let it rip.
Dur Da Dur
Re: Burnt ATF: to change or not to change?
If you're gonna put crappy ATF in it, don't do it.
If you're gonna put Amsoil in it, then change it.
P.S., don't forget to install a magnefine filter
Last edited by hondur; 03-22-2016 at 04:00 AM. Reason: I'm confident that the entire idea that changing ATF is bad came from people using crappy ATF.
Steve at Heart
I would change it and do the recommended flush procedure. I used Valvoline import fluid and then OEM Honda fluid for mine. Works just fine after 18k miles. When I got the car it was manually shifted between two gears.
I think RonJ has mentioned the Castrol Import stuff works well too.
OP- post your year and engine in the original post as well. Required for tech threads.
Three consecutive ATF drain-refill cycles. Between each drain-refill cycle, slowly shift through all gears several times with the engine running.
cabtank@aol.com
06-11-2019 08:37 AM
