a/c
Re: a/c (jdm91CrxSi)
when u said recharge it..do u mean diy recharge it ?or u have machine or a shop to evcuate and recharge.and also ..is ac compressor working fine? have u torn the ac components apart and reassemble together?
Re: a/c (crazyguy)
yea i did it myself with some 134a i mean i know how to release all the refg. but you can't let that **** go into the air.. talking about some fine. and yes comp. works fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">yea i did it myself with some 134a i mean i know how to release all the refg. but you can't let that **** go into the air.. talking about some fine. and yes comp. works fine</TD></TR></TABLE>
yeah u cant let the **** go into the air or expose to the air..how old is your dryer/reciver can ?? its whats keeping the ac cold..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">207 thousand miles old
but i just bought the 134a</TD></TR></TABLE>
yeah maybe time for a new ac dryer/reciver... it is a tear and wear part.. i used to have the same problem that my ac wasnt cold enough after had it evacuated and recharged by a shop...and then i couldnt stand the heat no more so i replaced a new dryer/reciver and ac is as cold as new again..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">where is the dryer/reciver is that near the firewall</TD></TR></TABLE>
it is the silver can sitting right behind the driver side headlight.. 2 10 mm to unbolt the bracket and 2 10mm ac lines bolts.. and pull it up... but before u do that..i forgot to ask u to check on the tension of your ac belt..
once u take it apart..u will have to get the whole ac system evacuate and recharged by a shop cause ac system wont engage if the ac system is not pressurized.. check the tensio on your ac belt..
and also what year is your ac sysem and your car?
neEven
07-23-2005 12:49 PM
