wheel stud replacement question
i know this had to have been covered before but for some reason my search function isnt working.. could any one provide me with a link to how to replace a wheel stud on a '93 civic? or just show me rite here
Re: (2wheelhunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero »</TD></TR><TR><TD CLASS="quote">Leroy, you are stupid as hell.</TD></TR></TABLE>
ok so i've dont dozens of engine swaps and turbo setups... rebuilt a couple of engines but i've never had to replace a wheel stud lighten up for christ sake
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">
i believe there are directions in the faq somewhere.</TD></TR></TABLE>
checked didnt see it...
any links?
any links?
Tools required:
* Man Hands
* BFH
* BFslideH (Autozone rental pn27032)
* 1x new stud
* Grease to pack in wheel bearings
1.) Jack up car, remove wheel in question
2.) Attach slide-hammer to hub assembly with two of the (hopefully) three remaining lug nuts
3.) Remove brake rotor / caliper assembly
4.) Commence sliding action to remove hub
5.) Beat the broken stud out with BFH
6.) Beat the new stud in with BFH. You may not be able to get it all the way in. If not, when you tighten the lugnuts on it will pull the new stud the rest of the way in.
7.) Pack some grease in the bearings
8.) Put everything back together. Installation is reverse of removal.
Hope that helped some.
* Man Hands
* BFH
* 1x new stud
Re: (Ek4_honder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek4_honder »</TD></TR><TR><TD CLASS="quote">damn, just got a stripped stud too three studs are enough</TD></TR></TABLE>
yes three was appearently enough when i ran my car at the track and did just fine... didnt know until after the fact that there was only three though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzadude »</TD></TR><TR><TD CLASS="quote">Tools required:
* Man Hands
* BFH
* 1x new stud
well yes and no.. that is how i thought you should do it.. but the slide-hammer didnt take off the hub last time i tried this.. is there another kind of hubpuller/seperator?
* Man Hands
* BFH
* 1x new stud
Re: (2wheelhunter)
That's the way I did it, and it worked for me. After about 30 minutes of slide-hammer action, the hub still hadn't moved out...at all. It just takes time and a lot of effort and that one final backwards slam that makes it separate.
SyntaxErRoR!
107
08-23-2005 07:33 PM
