leaky clutch master cylinder
i have like 2 streams of brake fluid coming into the cabin, and i was wondering if anyone know how long till the master will give up at this rate. also where should i get a new master cylinder from? can someone explain to me the bleeding process for installing a new master cylinder? thanks
well if it is leaking from the master cylinder, it is most likely the master cylinder LOL, i will just go to autozone tomorrow and pick up a new one. should run me like 50 bucks
Re: (shadohconspiracy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohconspiracy »</TD></TR><TR><TD CLASS="quote">i thought you have to close the valve before the person let the clutch back up so it doesnt suck more air in</TD></TR></TABLE>
Yes. Pump and hold down the pedal, release the bleeder valve. Close the valve. Pump again. Repeat.
Re: (BlueIntegraBoy)
what if i already have the bleeder valve open, then i pump and hold? close bleeder valve then let pedle up?
alright so basically hooke up the lines for the master and fill it all the way top with brake fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohconspiracy »</TD></TR><TR><TD CLASS="quote">what if i already have the bleeder valve open, then i pump and hold? close bleeder valve then let pedle up?
alright so basically hooke up the lines for the master and fill it all the way top with brake fluid?</TD></TR></TABLE>
You can do it this way. As long as you pump all new fluid through the lines to get rid of all the air.
