Spark plugs for high compression y8?
Hey guys, I'm wrapping up my build this weekend, and I'm not sure if I should get OEM spark plugs, or if something else might be better. It's a d16y8, with 11.0:1 cr. What do you guys recommend?
Re: Spark plugs for high compression y8? (sicones)
It looks like those are made for 99-00 si's... Are you sure you didn't mean ZFR4F-11. That's the same plug, but for 92-00 ex's.
Thanks for the quick reply.
Re: Spark plugs for high compression y8? (CALC!_JUST_du_IT!)
Why the hell would you want those, they're 1 step hotter, extended AND projected
the BKR6E-11 are 1 step cooler and non-extended
and btw those arent even for the EX civics, your stock plug is ZFR5F-11
