Having huge issues after swap was done.. wiring guru help appreciated.. 98 ek hb..
SO recently, i dropped in a vitara piston'd built D16Z6 with y8 tranny and y8 IM ..
This eh hb shell, was a theft recovery to start off.. There are splices and soldered plugs at both plugs for fuel pump. Then there is a 3rd plug that runs near brake hard line side near fuel tank which is also soldered since it was apparently cut..
Heres my problem..
You turn the key, and the first 2 clicks on ignition, nothing happens.. when 3rd position of thekey where starter engages, it makes the main relay start making a horrific buzzing sound and then radiator fan turns on as long as key is held in that position.
It does not engage starter at all. A few days ago, i had gotten it to turn over about 4 times, but has done this thing ever since then. No srs lights, brake lights or anything come on cluster until the 3rd position also.
Tonight i swapped motor harness, tried 3 diffrent main relays.. put a new dash harness in and changed ignition harness. i also replaced underdash fuse block, and also fuseblock in engine bay. I also tried 2 different ecus. Still not starting.
I had 2 of my friends look to make sure motor harness was connected properly and that i wasnt a retard. We think that the harness that goes from fuse block to fuel pump is possibly cut or whetever and grounding..
Does anyone else know what might be wrong?. Has this happened to anyone else before and what was the problem?. Aynything else i should look for?.
Any help is greatly appreciated.. thanks
Heres my problem..
Re: Having huge issues after swap was done.. wiring guru help appreciated.. 98 ek hb.. (gotnos2)
if it was me, id go to honda and get an entire wiring diagram for the car. and tear everything out of it, check every wire, and replace any spiced or soldered harness with a new one. its hard to diagnose a wiring problem like that without having it in front of you. so the best i could say is double check everything
Thats pretty much what i have been doing.. basically eveything from the dash forward is new...
I have a helms manual on disc, with all wiring diagrams.. Thats exactly what point im at right now.. I do not know what else to do..
But it does sound obviously like a car wiring harness problem to you also right?..
Re: (gotnos2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">if it was me, id go to honda and get an entire wiring diagram for the car. and tear everything out of it, check every wire, and replace any spiced or soldered harness with a new one. its hard to diagnose a wiring problem like that without having it in front of you. so the best i could say is double check everything</TD></TR></TABLE>
Sounds like a solid plan
Thornton121
08-26-2014 04:09 AM
wakn
03-22-2013 08:10 AM
0to60in5
16
08-24-2009 08:15 PM
1crazysir
10-09-2006 02:16 PM
