MOMO HuB wont come off
Re: MOMO HuB wont come off (robble36)
You can go to Autozone and rent a steering wheel puller. I had trouble pulling my momo hub that was stuck, but it came right off when I rented that puller. It is easy and fast
Re: MOMO HuB wont come off (Ritchie)
will that steering wheel puller work with a nardi wheel? i already have a quick release on but im using a whole new unit
It should, but not quite sure. My momo steerin wheel was off when I used the steering wheel holder. Best bet is to take out your wheel first in order to take the hub off.
haha you dont even want to see what the steering wheel puller did to my hubb ahaha but ya i got it off with a gear puller and i aligned the NRG unit and **** so im all good now but if you want to see a picture ill post it in here haha
* B A N N E D *
loosen the 19mm nut in the center, but dont remove it
then put the steering wheel back onto the hub, and wiggle the steering wheel while pulling, it should eventually come off
the reason you keep the 19mm nut is so if it flies off, it doesn't smack you in the face
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">loosen the 19mm nut in the center, but dont remove it
the reason you keep the 19mm nut is so if it flies off, it doesn't smack you in the face</TD></TR></TABLE>
trust me i tried everything before i posted this thread except the wheel puller... that seemed to be the remedy but just look what the wheel puller did to the hub haha .. it took a gear puller with like 4 legs to finally get it out and even with that we struggled...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">You can also put the point of a philip's head in the hole on the steering column and beat it with a hammer. That helps loosen it.</TD></TR></TABLE>
i did soemthing similar to that .. again no use
here are the pictures
Re: (Ritchie)
ya its because it was sooo tight and stuck on there the wheel puller couldnt get it and i was torquing it soo much it stretched the metall haaha we had to use a gear puller and we torqued the crap out of that too and it finally popped off .. before i installed my new hub i used WD40 on the splines so it can be somewhat lubed in the future for when i have to remove it again for some reason hah
citanest
04-17-2002 01:02 PM
