92-95 SIRII rear disk on 94 ej1 coupe ABS?
ok ok ok.... ive searched and searched....
ive only found stuff on teg disk swap....
are the sirII disks the sake as 92-95 si hatch?????
will everything bolt up directly ??????
do i need to buy teg or whatever parts to get this swap to work????
and ive seen mixed reviews on prop valves. im totally confused on this matter.
I have the SiRII rear disks on my 92 hatch. plug and play. (other than the LCA's they are ITR style)
but I don't have ABS and the rear disks that I have do not have the ABS sensors.
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">I have the SiRII rear disks on my 92 hatch. plug and play. (other than the LCA's they are ITR style)
but I don't have ABS and the rear disks that I have do not have the ABS sensors.</TD></TR></TABLE>
yes, the jdm rear disc are used with no abs. but i agree, they are plug n play affair.
ok, i could have sworn my car was abs, but i looked again and i didnt see the huge clusterfuck or lines that abs has. so i dont have abs!!! yay!!
ok, what about the actual rotors??? what rotors will work on them?? and what rear pads also??
teg? si civic? type r?
Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 »</TD></TR><TR><TD CLASS="quote">ok, i could have sworn my car was abs, but i looked again and i didnt see the huge clusterfuck or lines that abs has. so i dont have abs!!! yay!!
teg? si civic? type r?</TD></TR></TABLE>
yes the rotors, pads, and calipers are all the same.
jdm civic sir2
usdm:
94-95 civic ex/si
94-01 integra
94-97 del sol (DOHC VTEC)
96-00 civic ex/si
90-93 integra
and you have a 94 coupe, so i'm taking it's not a ex. so yes you do not have abs. abs start on the civics 94-95 and were only found on civic ex's and si's.
jdm civic sir2
usdm:
94-95 civic ex/si
94-01 integra
96-00 civic ex/si
90-93 integra
i have a 94 ex coupe.
i do not see anything under the hood that would include abs???? ill post a pic
dont cars with abs usually have a big assed boxy looking thing under the hood showing brake lines out the ***?
Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 »</TD></TR><TR><TD CLASS="quote">i have a 94 ex coupe.
dont cars with abs usually have a big assed boxy looking thing under the hood showing brake lines out the ***?</TD></TR></TABLE>
yes, you do not have abs.
for me, it's hard to tell from that pic.
pic of a civic ABS setup...
http://importnut.net/swappics/abs.jpg
Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">what is that tiny bottle by drivers fender by hood support. It may be ABS fluid level check. </TD></TR></TABLE>
I hop your joking, if not it sounds like your talking about the ac check glass
Re: (egsleepercivic)
... you have powersteering with a swap.. amazing!
Re: (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">yes the hardlines are the same, but you do need diskbrake e-brake cables</TD></TR></TABLE>
and the 92-95 SI or 99-00 SI rubber hoses.
Good time to upgrade to SS lines.
Re: (graveltravel2)
No, you do not have abs. If you really wanted to know if you had abs. Look by the battery. There you will see the abs module and you will see a little fuse box bolted up to the shock tower right beside the intake box, which you don't have. As far as the rear brake lines. You can't use the one for the drum brakes(from the fender well to the drum). Get brake lines from a 94-95 civic si, 94-95 civic 4dr. w/abs or 94-00 integra.
damn... you guys have been helpful
im suprised to see any "search" replies yet...
i assume by fenderwell , that you mean rear fender well, right? lol
i need to find a step by step install. haha
Re: (graveltravel2)
yes, the rear fender well. you will see where the brake line connects to the hard line. here you will see clearly where. In the picture they have ss lines.
