different clutch suggestions?
just looking 4some suggestions about what kind of clutch setup should i get for my ej8 civic coupe, beacuse my oem clutch is about to go out, any advice would be great?
Darth ModerVader
Re: different clutch suggestions? (TheGreatOne84)
If you aren't making significantly more power than stock, the OEM unit is perfectly fine. It's a good opportunity to install a lightweight flywheel, however.
Re: different clutch suggestions? (Padawan)
sounds good beacuse when i go into 1st, 2nd, and 3rd gear after i let go of the clutch it starts making a whinning noise and it sounds pretty serious?
Re: different clutch suggestions? (Nihonjin.Desu)
i have a JDM B16A with exedy stage 2 and it gives a "stiffer" feel which i like... makes my shifting more positive a feels better... a fidanza 8lb flywheel with the exedy stage 2 is hard to beat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGreatOne84 »</TD></TR><TR><TD CLASS="quote">sounds good beacuse when i go into 1st, 2nd, and 3rd gear after i let go of the clutch it starts making a whinning noise and it sounds pretty serious?</TD></TR></TABLE>
Whining, like screeching metal or something of the like? Because I had that when I swapped my engine. Yes, I was impatient and just wanted the engine in the car without waiting for the clutch kit to come; mistake.
When I took the transmission out, the clutch plate was worn down past the pads, smooth, and the springs on it had been hitting the flywheel bolts and smoothing themselves out substantially. I would venture a guess that your clutch is in fact going out. Just go for the Exedy Stage 1 Organic replacement, new throwout bearing (as mentioned before, is included in most kits), and a lightweight flywheel.
Oh, a shortshifter could also be in order for you, while you're under your car. I really like mine.
carbone
Transmission & Drivetrain
10-08-2015 09:18 PM
