Noob question
Noob question
Hey i have a d16y5 engine and i am not at all sure if it is vtec i don't know that much about engines so please don't bash on me i tried to search it, but i cant get any real answers, also if anyone knows if it is a good engine please let me know thanks and sorry for the noob question, but when you don't know just ask
check this out:
SOHC VTEC-E
Honda's next version of VTEC, VTEC-E, was used in a slightly different way; instead of optimising performance at high RPM, it was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve.
SOHC VTEC-E
coupishEK
07-21-2008 02:14 PM
