compression test results...
did 1st compression test on my 98 civic
d16y8 100000 miles
warmed engine till fan came on , removed fuel injector fuse... unplugged what you young guys call dizzy.. im catching on!!!
removed all spark plugs..
checked every cylinder by full open throttle .. cranked engine 5-7 times checked reading...
1st cylinder 150 psi / 2nd 170 psi / 3rd 170 psi/ 4th 180 psi
2nd reading same
talk to me guys
how do these numbers look???
d16y8 100000 miles
2nd reading same
talk to me guys
Sounds like the exhuats valve is going bad, might wanna take a look at that. Although it at that little bit of a deviance in pressure you may not want to take the head apart just to find out.
Re: compression test results... (BlueIntegraBoy)
worn rings??
do i need to look into this right away??
car runs great
i've had for a little under three months
daily commute 50 miles
one way!! needed economical vehicle
found this honda
starting to enjoy the hell out of this car
compression test worries me!!
car runs great
found this honda
I said valve, not ring, you are confusing the head/valves with the block/pistons. Take a look at this site and you may understan better http://autos.yahoo.com/maintai....html
Re: (Ron454321)
lol
ron.. i posted my prevoius post before i saw you post ...
i do know the differance between head and block
i need to type faster.. thanks for your help
JasonST
10-25-2007 05:28 PM
Chubz
06-27-2002 02:00 PM
