Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods....
Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (0TT)
whats the black box for under the cup holder.
Clifford Concept 650 MK2 alarm system that also has remote start, turbo timer, window roll-up/venting by remote, dual zone proximity sensor, digital tilt & motion sensor, black-jax anti-hijacking and various other othtions.
Its a fresh inport from Japan, EK9, extremly clean, inside and out. So I didnt want to take my chances with having it stolen as NO japanese car comes with an alarm, some newer ones come with transponder immobiliser key but not the 98 Civic Type-R which is what mine is.
Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (MugenManR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR »</TD></TR><TR><TD CLASS="quote">whats the black box for under the cup holder. </TD></TR></TABLE>
Looks like a main unit for a alarm.
I've place my radio in that pocket, so its the same size as the upper one.
Easiest way is probably using a block off plate with three holes.
Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (bobobob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobobob »</TD></TR><TR><TD CLASS="quote">
Easiest way is probably using a block off plate with three holes.</TD></TR></TABLE>
Sizes are:
1-Din radio size is= 7.5"x2.5"
Pocket is 7.5x2, surrounding fascia area is 8.25x3.75" and 3.25 deep
Not the same size!
Sizes are:
Not the same size!
Re: (0TT)
Re: (ariza034)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ariza034 »</TD></TR><TR><TD CLASS="quote">something like this..</TD></TR></TABLE>
I have ordered the triple-gauge single-din pod like in the website BUT, I need the part of the factory centre console that IS 1-DIN sized so I can put it in
you need to get a block off plate.. nobody makes a guage pod for that spot. just get a block off plate... Drill the holes for your guages put em in and wire em up... its actually simple..
52mm drill bit.
the block off plate
drill.
only things youll really need.
52mm drill bit.
the block off plate
drill.
Thanks guys, ive realised i measured the outer edge of the radio fascia, not the actual size. D'oh.
Im ordering a 1-DIN sized triple guage pod from a tuning shop here.
coll9947
12-14-2005 05:34 AM
