MANUAL TO POWER STEERING SWAP - need help
I have a 93 dx, with b16a2 2000 si motor installed. I got the ps rack, and now ill put it in.
my problem is i need a pump and bracket, but dont know which to get. They keep asking what "ID' number i need for the pump and bracket. Does anyone know. Its just normal b16a2
Re: (Relic1)
BUMP someone i know can answer this just spend a few seconds to reply. Is my 93 power steering rack going to connect to my 2000 si pump?
* B A N N E D *
Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">BUMP someone i know can answer this just spend a few seconds to reply. Is my 93 power steering rack going to connect to my 2000 si pump?</TD></TR></TABLE>
no it wont
eg's have the small offset hole ps pump, ek's and dc2's have the inline big hole ps pumps
96-00 civic/94-01 integra on the left, 92-95 civic on the right
no it wont
Re: (n1_egsex)
so then since i cant do that....could i use the 96-00 ps rack and mount that to my 93dx steering column..
if so then im problem free
Re: (drumminforev)
come on guys, simple question!
can i just use the 96-00 rack
do i need specifially the 99-00 SI rack?
or is it possible just to swap lines and use the 93 ps rack with the 00 ps pump....any reason why i couldnt switch the lines?
Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">bump, i helped this forum out with my AC GANGSTA thread, so dont see why anyone shouldnt help me.</TD></TR></TABLE>
relax man! just because you might have done the a/c thread doesn't mean every member on here has to stop what they are doing to post for you. remember, there are alot of new members on here, some learning as they go, you know.
as for your question. if you are using a PS system of any 92-95 civic, then you are going to have to get the pump and brackets off of a 94-95 del sol (b16a3).
this will bolt straight up without any problem.
as for a 96-00 system, not sure if the line from the pump to the rack is the same, but i know for sure you cannot use the rack on your 93 civic. the subframe is alittle different.
Re: (philosofy1)
If you get the 96-00 rack then the lines are going to be different and your going to need the 96-00 pump. I say just find a 92-95 rack,lines,and pump. This way you will not run into any problems.
Re: (ejoner)
The problem there is my engine is 2000, so how is a 93 rack pump and alll that going to work.
OK IM ASKING SIMPLE QUESTION
WHICH PUMP DO I USE.I have 93 civic with b16 sawp.
DO I USE 92-95 rack and pump OR 96-00 RACK AND PUMP, OR MIX THEM, AND WHICH WAY WOULD I MIX.
Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">[B]The problem there is my engine is 2000, so how is a 93 rack pump and alll that going to work. </TD></TR></TABLE>
It doesn't matter what year your engine is. Its just that the 93 del sol is a B series and your motor is a B series thats all that matters.
I don't know if this helps any.
I did a B20 swap into a 99 Civic Sedan.
I used the B20 PS bracket, and the stock 99-00 civic PS Pump.
I assume you will have to get the B16 PS bracket, and lines, rack, and pump from a 92-95.
94CivicSi
07-31-2008 08:34 AM
