Soft brake pedal and running rough
I swapped my 97 DX with a d16y8 and I have a few issues. First is the brakes. When I started to drive it and hit the brakes they didn't do anything, I hit them a couple times and they started working a bit but there isn't much pressure. Pressure seems fine when the car isn't running. Also, the car is running pretty rough and I'm not sure why. I never set the ignition timing, do I need to? I read that it will put itself where it needs to be unless you jumper it when you set it. I have engine codes p0453 and another for no secondary o2 sensor because the cat was deleted. I checked the cam timing and it looked good.
re: Soft brake pedal and running rough
Did you hook up the brake booster vacuum line? This would do both, makes the brakes worthless as well as cause your engine to run horribly.
And yes, you still need to set ignition timing just to be sure it's correct.
Did you swap your ECU too?
Y7 intake manifold? Or just intake?
If manifold that explains why it's running like crap, but you still need to do ignition timing.
Technical Hero
Is this a manual car? If so you'll have to use a 2 IACV and a manifold that accepts that plus do the wiring. Did you wire up VTEC and knock?
I didn't get a Y8 intake manifold, the only one I could find was automatic and it doesn't have the IACV mounting on it. I figured if I swapped the injectors over it would be ok though. Could i use the automatic Y8 manifold and the Y7 throttle body since I believe the Y7 has the IACV on the tb?
With a manual EX ECU, you have to use a 2-wire IACV, which is only found on the manual EX intake manifold. I think the injectors are the same for all models.
The brake issue is probably a coincidence, diagnose it separately. Did the brake rotors rust up while the car was waiting for engine swap? Could also be air in the lines or worn master cylinder.
Re: Soft brake pedal and running rough
I'm ordering a manual IACV from eBay and tapping my automatic Y8 when it gets here. For now I got it running pretty good, I put in new plugs and switched back to the Y7 ECU for now. Still haven't figured out the brakes yet though. The drivers side rear had been locked up, and when I took it apart it was mangled and things were rusted/missing so I replaced the cylinder and brakes and put it back together and bled it but still have almost no brakes. Unfortunately all my bleeders are stuck, I tried PB but they wouldn't come. The driver side rear broke which is why I had to replace the whole cylinder. Any ideas on how to free up the bleeders?
Would this also cause a loss of power at 3k rpms (also have a hard brake pedal while running)? thinking I have a leaking booster myself on a '92 EG8 I recently bought, but was thinking of checking the timing as well just to make sure.
You should start a new thread. No, a vacuum leak wouldn't cause a problem off of idle speed. Inability to rev over 3000 but no CEL codes is usually because the timing belt and/or distributor is off time.
Fish Twig
You need to drill it out.2 big holes and 2 small holes, the 2 small holes will have to be tapped to bolt in the iacv. Yes the 2 wire iacv is need because the ecu looks for it.
If leaving the auto throttle body and unused three wire IACV you should fabricate a blank plate to put under the IACV gasket to block it off. This can be very simple for example use tin can material.
Blocking it off removes it from the equation.
