Help! Broken vehicle speed sensor
So long story short, my speedometer went out on my em1
ordered new replacement one. Seems like a strait forward install but not so. Removed the 10mm bolt and was trying to pull sensor
well the unthinkable happened the sensor snapped off and leaving a portion still mounted in the transmission. My question is what are you're options on how to extract the left over damaged sensor.
It will not pull out..
any input please
any input please
Re: Help! Broken vehicle speed sensor
What convinced you that a bad VSS caused your speedometer to stop working?
Post clear pictures of broken VSS in transmission.
Well, yes speedodm stopped working,
its out with some effort I had to chip away carefully with a flat head screwdriver finally broke it in four pieces, came right out "piece of ****"
its out and new one in and we'll still don't work ?? I know cluster works because before swap it was working
Think it's the engine harness issue, 97 civic hatch using the wire harness for a 99 b16a2 only two plug harness, looking for a ex 96-98 harness got the car this ways it's going to be a work in process
Mixing OBD2a and OBD2b harnesses is risky, but do some diagnostic tests rather than throwing parts at the problem. Turn your VSS wild goose chase into a learning moment.
Fish Twig
any input please
any input please
Freckles
08-20-2012 10:30 PM
