CEL for IACV/EVAP-Civic 2000 si with GSR B18C1
so ive had this car for 2.5 years now... im in upstate NY, of course and you can't have check engine light on. We've done so much to it, its insane. Current status is trying to do a drive cycle without any codes popping up and the 3 codes to clear. well the latest codes that popped up was IACV and EVAP. There was still air in lines which we got out and now nothing has popped up yet .... cross my fingers lol what other things could all of a sudden make IACV pop up because it never did before... It has new almost everything seriously... I just replaced the speed sensor which was $175 later, it has new O2 sensors, new after market Skunk 2 header, wires, plugs, TPS sensor, radiator, thermostat, stage 3 clutch, stage 3 flywheel, short shifter, new battery, full racing exhaust, drilled n slotted rotors, new timing belt and water pump, distributor, motor mounts, etc. The list goes on n on so... any ideas or suggestions on just getting the damn thing on its way would be helpful.... I just wanna drive my baby THank you in advance
Re: CEL for IACV/EVAP-Civic 2000 si with GSR B18C1
yes sometimes it feels like it wants to stall, the rpms fluctuate low to high,
we did replace the TPS sensor and the Speed sensor we replaced just last week.
Test the ECT sensor, bleed the cooling system (see service manual for your B18C1), and adjust the idle speed.
Is P0505 gone now?
Is P0505 gone now?
efnnhatch
09-10-2015 11:07 AM
