bought EJ6 with aftermarket upper control arms - need ball joints
Can anyone tell me who makes these, I need to replace the ball joints. I bought the car with aftermarket coilovers, and upper control arms already installed. Where can I find the tool to adjust the springs on the coilovers?
Regular or OEM upper control arms wouldn't work because of the adjustment needed due to the coilovers, correct?
Thanks!
Re: bought EJ6 with aftermarket upper control arms - need ball joints
No, OEM works fine and I'd suggest that for longevity. The tool for the coilovers is called a spanner wrench and you can buy them anywhere online.
Spanner is just another word for wrench, but I guess you mean coilover spanner.
The only problem I see with using regular upper control arms is the ball joints are at the ends of the arms, while the ones I have now the ball joint is in a slotted track and can be loosened and moved to adjust camber.
I think maybe my camber will be off if I use normal upper control arms.
Nothing a alignment can't fix
I guess that makes sense, the tie rod ends should have enough adjustment left. I guess I will find out.
Seagull Management
Skunk2 sells replacement upper balljoints for their adjustable upper arms. I'm not sure if that's what you have, but from what I can see they look like Skunk2 upper control arms.
kamikazie
10
01-10-2013 08:44 PM
