1995 HONDA EX CIVIC WONT START! PLEASE HELP!
i bought a civic coupe it blew an ICM the first night i bought it so i replaced it, it blew again so it would only Crank and crank but no spark. After the 3rd ICM it finally fired up, drove it to my friends house because he has better tools. parked it, only to find out that the next morning it would crank and crank but no spark. Also fuel pump no longer priming, i used a different main relay already. HELP !
Re: 1995 HONDA EX CIVIC WONT START! PLEASE HELP!
Turn key from OFF to ON(II).
Watch the CEL. Does it turn on and stay on? Does it turn off after 2 seconds? Does it never turn on?
Now that is incorrect
96 ex meaning vtec d16y8 only have crank sensor located on timing belt crank pulley
WE may be confused as to where the ckp is located
BIt 88-00 run ckp cup non vtec thru dizzy
In addition to the three distributor sensors (CKP, TDC, and CYL or CKP), 96-00 Civics also have a CKF sensor -- CKF DOES NOT equal CKP. Get your facts straight before you post. You are making a common newbie mistake.
OP reports that the fuel pump does not prime, that is a problem that doesn't have anything to do with the distributor. The main relay, ECU, and basic power / ground systems are involved in that.
Acuralovin
05-20-2016 04:40 PM
Justin1168
10-01-2014 08:20 AM
mynameizstitch
03-17-2012 10:55 AM
