93 civic ex auto to manual conversion
So I'm trying to convert my 93 civic ex 2dr coup automatic to manual. Now I know I need the trans, ecu, pedal, shift linkage, and shifter from the donor car. But what I'm wondering is if there is anything else I need to make it work. Also would the axles from the automatic one work with theannual one? Both my car and the donor are completely stock if that makes a difference thanks.
Re: 93 civic ex auto to manual conversion
Heres a link that may help https://honda-tech.com/forums/honda-...4pics-1337459/ Pm Luserkid with help i was just talking to him about my questions he answered all of them, Hes a good guy!
- SincerelyAn 00' Civic ex brother
You're good with using the auto axles bud ! Glad to see another ex brother , After some research on doing some from 92-00 you can use your auto axles
https://honda-tech.com/forums/honda-...no-no-2090074/
http://www.d-series.org/forums/diy-f...nual-swap.html
https://honda-tech.com/forums/honda-...ap-eg-1316692/
Seagull Management
The automatic axles are the same. When swapping the pedals the automatic throttle cable is different at the pedal end so either swap the pedal or keep the automatic gas pedal (using the automatic pedal and cable it's a bit springy) You don't really need the ECU either, automatic P28s are easily converted to manual if you can solder. As mentioned you'll need a swap mount or you'll need drill the spot welds out of the bracket welded to the passenger's side frame rail to remove it and then weld on the bracket from a manual Civic.
angrysmileyface
10-07-2014 07:48 AM
angrysmileyface
05-22-2014 11:55 AM
civicguy395
11-26-2012 04:11 PM
coasttime
08-21-2009 04:38 AM
