93 Civic with a D16Y8 - Alternator Question
So I am pretty strapped for cash right not but I grabbed an alternator from a pick yard and it failed a test at Autozone. I went back to get another one as a replacement with my warranty and it also failed.
So my question is I want to say I read somewhere about alternators from the civic not charging unless it was under some high stress (high RPM), just cant find anything about it now....
Am I really getting this unlucky with them failing or is the test giving a false negative?
If it helps I had a fail on the L side, not sure what that means though.
Thanks for any help, probably going to head back in the morning and give #3 a try.
re: 93 Civic with a D16Y8 - Alternator Question
The "L" circuit's only function is to turn the dash "battery" light on when the alternator detects it has a problem.
The test at the auto store may not be accurate. You should try the alternator in your car. R&R alternator is a pretty quick job once you have the bottom bolt broken loose and able to slide out.
The Mitsubishi alternators tend to last 200k miles or more.
Re: 93 Civic with a D16Y8 - Alternator Question
Well to describe the old issue. I was driving home one night and the battery light came on. Car died less than a mile from home and had to get the wife come jump me off. Took the volt meter to the battery and it was only reading 12 so I checked what connections I could on the alternator and did not have a change on the battery. The previous owner did not keep this car clean and it had an oil leak on the VTech soleniod (replaced the gaskets) and I think eventually oil caked up on it and killed it one way or another.
I ended up getting the second alternator checked at another Autozone and to my surprise it passed. I put it on and I am getting a very minor squeak from what I can only describe as the bearing on the alternator. I am going to let it go for next couple days and see if tightening the belt (in case I am mistaken). If it doesn't I am open to suggestions but will consider swapping to another one from the junk yard.
(No thread jack) and I am well aware you don't work at AutoZone
marcus029
12-10-2007 01:10 PM
GRM Scott
07-15-2002 11:05 AM
