Broken Muffler Bolt
Broken Muffler Bolt
So I completely broke the bolts holding my muffler. So the weird thing is that the nut is welded to the exhaust flange. Do I just hack the nut off and the rest of the bolt that is threaded to the nut should just fall out, right? I thought about using my angle grinder but sparks and the gas tank nearby scare the heck out of me.
talks to himself
Re: Broken Muffler Bolt
Cut it like you suggested or try to get on it with a vice grip and turn it out.
Cool Cool Island Breezes. BOY-EE
Remove? The? Exhaust? So? It's? Not? Near? The? Gas tank?
My brilliance is pure.
Or use a cutting method that doesn't involve sparks.
Or use a breaker bar/impact to break the welds on the nut.
Unless your gas tank is leaking, really the "sparks" from your grinder are cold by the time they fly two inches.....
But yeah, you could also do a make shift cardboard shield to prevent the sparks from ever getting to the tank.
Drill and retap is your best option if you are concerned. Oh also, if you have a full tank of gas, it has much less combustibility. It's the half tank that is most volatile.
VtecAddict96
06-01-2013 03:46 AM
droppedcivo
04-22-2003 09:53 PM
