having problems with clutch.
well this has happened twice to me while driving my 94 hatch, the clutch would lose pressure and it wouldnt be enough to engage the gears. the first time it was cause i ran out of clutch fluid so i added more and bled it. the second time fluid was full but as i was driving i had clutched in and felt and heard a little pop and instantly lost pressure to my clutch but the pedal didnt drop to the floor i tried re-bleeding it but still didnt gain any pressure. im guessing it may be my slave cylinder or i need a new clutch. i never really had any problems puting my car into gear.
the car has 160,XXX miles dont know too much of the maintanence done from previous owner.
Re: having problems with clutch.
check your master and slave cylinder. have someone sit in the car with it on, and pressing on the clutch, on and off, and look for leaks. my clutch leaked at the slave cylinder (right where it engages the clutch fork for the tranny) so I replaced it and I haven't been leaking since.
whats the time frame on losing pressure? mine was a fast leak so it was obvious. if you have the money might as well do precautionary upgrades on the master and slave, but that's just me.
mine was pretty quick but with no leaks but im thinking of replacing my slave if thats causing the problem. or just save up for a b series swap and change everything.
In a closed hydraulic system, i.e. your clutch any signs of fluid loss means there is a leak. Have you checked the master or slave? Have they been rebuilt more than once?
Sometimes the seals in the master cylinder or slave are worn out just enough for the fluid to pass through without showing any signs of leaking.
Nations Sickest CRX
08-30-2005 03:53 PM
